It is currently Fri Jan 30, 2015 8:08 pm
 Post subject: Whats the best way to clean a cpu of the stock thearmalpast
PostPosted: Fri Mar 18, 2005 8:50 am
I just got a new hsf and need to know the right way to clean a barton 3000+ to get the stock paste off the cpu core
PostPosted: Fri Mar 18, 2005 8:58 am
King of All Voodoo2 Cards
I use a bunch of q-tips
PostPosted: Fri Mar 18, 2005 9:05 am
ok but what kind of cleaning soulution should i use?
PostPosted: Fri Mar 18, 2005 9:18 am
None, I polish that thing with Qtips till it's spotless
PostPosted: Fri Mar 18, 2005 10:12 am
use alcohol, it dissolves it nicely and leaves it nice and clean.
Contributing Writer
Contributing Writer
I use q-tips and at least 90% isopropyl alcohol, alternating between wet and dry. Once no more gunk is being picked up, I give it a final 'buff' with a dry q-tip.
PostPosted: Fri Mar 18, 2005 11:45 am
Rubbing alcohol (isopropyl alcohol if you must be technical). It evaporates quickly (notice it feels cool when you rub it on your skin? This is why) so don't be afraid to soak the tip of the Qtip.
PostPosted: Fri Mar 18, 2005 4:18 pm
thanks for the tips i'll be putting it on over the weekend time permitting. i'll let you know how it went.
