It is currently Tue May 21, 2013 5:16 am
 Post subject: Anything wrong with this build? (or improvements)
PostPosted: Mon May 07, 2012 2:29 am
I want to know if there is any incompatibilities or improvements i can do with this build, ive looked into it but I would like the Knowledge of some superior builders, since this is my first time. :)
(note that I don't need a mouse)
Thermaltake Black Chaser MK-I Full Tower
Gigabyte Radeon HD7970 Overclocked 3GB
G.Skill F3-14900CL9D-8GBXL 8GB (2x4GB) DDR3
Intel Core i5 3570K
Hitachi Deskstar 7K1000 500GB 7200RPM
Pioneer DVR-219L DVDRW OEM
ASUS Sabertooth Z77 Motherboard
Corsair GS-600 Power Supply
Gigabyte GK-K7100 USB Ultra Slim Keyboard
TP-Link TL-WN881ND Wireless N PCI Express Adapter
 Post subject: Re: Anything wrong with this build? (or improvements)
PostPosted: Mon May 07, 2012 9:42 am
The ASUS Sabertooth I'm iffy about, mostly because I see it as a flashy motherboard that costs more than it's worth. You can skirt by with a good quality motherboard that's $120 or so if you look around. And then you can have some room for a small SSD for the OS.
PostPosted: Tue May 08, 2012 12:21 am
[quote="LatiosXT"]The ASUS Sabertooth I'm iffy about, mostly because I see it as a flashy motherboard that costs more than it's worth. You can skirt by with a good quality motherboard that's $120 or so if you look around. And then you can have some room for a small SSD for the OS.[/quo
yeah i was thinking that, do you have any recommendations?
PostPosted: Tue May 08, 2012 12:08 pm
Unfortunately no, since I haven't been up to date with motherboards (I usually don't until I need a new computer).
Basic approach to this is figure out what IO you need, then go narrow your search on say Newegg. When you find something that looks good, go do research about the product (like product reviews and whatnot)
