It is currently Thu May 23, 2013 10:52 am
 Post subject: Building my first pc!
PostPosted: Fri May 04, 2012 11:22 pm
So this is what i got so far.
ASUS P8Z77-V LK LGA 1155 Intel Z77
COOLER MASTER HAF 912
Intel Core i5-2400 Sandy Bridge 3.1GHz
CORSAIR Vengeance 4GB
Rosewill RP600V2-S-SL 600W
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X
my budget is around $800. i want to be able to run most recent games at mid to high settings. and i might be using this for video and photo editing. im having trouble on deciding what gpu and hdd to choose. i prefer nvidia.
 Post subject: Re: Building my first pc!
PostPosted: Sun May 06, 2012 10:58 am
you can get these
SAMSUNG Spinpoint F3 HD103SJ 1TB $110
GIGABYTE GV-N560OC-1GI GeForce GTX 560 Ti $230 w/ $20 MIR
and even bump to 8Gb ram (combined w/ the 1Tb, will be very helpful for video editing)
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 $42
just have to swap out a few things to recover some cost
BIOSTAR TZ77B LGA 1155 Intel Z77 $100
Rosewill Green Series RG530-S12 530W $50
I went w/ that mem & board since you won't be OC'ing the non-k i5, and that PSU is better (80+ and true-rated high temp), will be more than enough....
System Type: 1 physical CPU
Motherboard: Regular - Desktop
CPU Socket: Socket LGA 1155
CPU: Intel Core i5-2400 3100 MHz Sandy Bridge
CPU Utilization (TDP): 90% TDP
RAM: 2 Sticks DDR3 SDRAM
Video Card 1: NVIDIA GeForce GTX 560 Ti
Regular SATA: 1 HDD
DVD-RW/DVD+RW Drive: 1 Drive
Fans
Regular: 1 Fan 80mm; 1 Fan 92mm; 2 Fans 120mm;
Keyboard and mouse: Yes
System Load: 90 %
Minimum PSU Wattage: 315 Watts
Recommended Wattage: 365 Watts
should be exactly $800 on the egg's cart 8) just add shipping for some of the components (well worth it) will be a nice build.
PostPosted: Sun May 06, 2012 8:25 pm
thanks for the response. is there any tips or advice i need when installing everything?
PostPosted: Sun May 06, 2012 8:54 pm
thanks for the response. but does the video card have to be $230?
Users browsing this forum: Google Adsense [Bot] and 3 guests
