It is currently Wed Jun 19, 2013 6:00 am
 Post subject: first budget gaming PC build
PostPosted: Sun Apr 29, 2012 4:27 pm
So this is my first build and these are the parts I have selected could anybody give me there opinion
1 x ($79.99) AMD Athlon II X3 455 Rana 3.3GHz Socket AM3 95W Triple-Core Desktop Processor
http://www.newegg.com/Product/Product.a ... 6819103911
1 x ($64.99) SAPPHIRE 11192-22-20G Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video
http://www.newegg.com/Product/Product.a ... 6814102988
1 x ($59.99) BIOSTAR A880G+ AM3 AMD 880G HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.a ... 6813138283
1x ($44.99) APEX AL-D500EXP 500W ATX12V Power Supply
http://www.newegg.com/Product/Product.a ... 6817154026
2 x ($21.99) Patriot Signature 4GB 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Product.a ... 6820220480
1 x ($21.99) APEX SK-393-C Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.a ... 6811154109
1 x ($4.99) Rosewill Case Fan 120mm
http://www.newegg.com/Product/Product.a ... 6835200048
I already have a hard drive and optical drive any tips about this current build would be appreciatedthis is my first build and in on a tight budget
 Post subject: Re: first budget gaming PC build
PostPosted: Mon Apr 30, 2012 10:05 am
I would say, swap out the case and power supply. For the case, a newer bottom-PSU style helps out with system cooling quite a bit, try one of these instead
HEC Blitz Black Steel Edition ATX Mid Tower $40 w/ free shipping ($25 instant) ** excellent deal (I would pick this one, pretty sturdy case)
COOLER MASTER Elite 311 $45 w/ free shipping (one of the standard cases I use in budget builds)
The HEC Blitz has 2 fans already, so no need to purchase an extra one. That is a great deal I may also pick up one for myself just to have for my next budget build! 8)
I highly recommend a green 80-plus unit nowadays try one of these
COOLER MASTER GX 450W RS450 $45 + $2 shipping & $10 MIR
Rosewill Green Series RG430-S12 430W $45 + free shipping ($20 instant)
CORSAIR Builder Series CX430 V2 430W $45 + $2 shipping ($5 instant and $10 MIR)
All these have good reviews from reputable sites, I would take either one of those over the one you picked since it is probably not "true" rated (would not stand up to rigorous testing to a real 500w, the three above can actually handle the stated power on the label).
If you are worried about your system needing less than a 500w psu, no worries... AMD based systems are very power efficient:
System Type: 1 physical CPU
Motherboard: Regular - Desktop
CPU Socket: Socket AM3
CPU: AMD Athlon II X3 455 3300 MHz Rana
CPU Utilization (TDP): 90% TDP
RAM: 2 Sticks DDR3 SDRAM
Video Card 1: AMD Radeon HD 6670
Regular SATA: 1 HDD
DVD-RW/DVD+RW Drive: 1 Drive
Fans
Regular: 1 Fan 80mm; 1 Fan 92mm; 1 Fan 120mm;
Keyboard and mouse: Yes
System Load: 90 %
Minimum PSU Wattage: 203 Watts
Recommended Wattage: 253 Watts
cheers
PostPosted: Mon Apr 30, 2012 10:18 am
You said this is going to be a gaming PC. What games are you going to play and what is the resolution of your screen?
PostPosted: Mon Apr 30, 2012 10:24 am
Would you be willing to swap the AMD system for a Intel Sandy Bridge based Pentium system? It's about the same price and you get a little more oomph.
