It is currently Sat Feb 28, 2015 1:14 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: Building Top end Pc and going insane!!!!!
PostPosted: Thu Mar 17, 2005 10:12 am
I built a Pc last summer but as my GF needs a new comp I figured I would give her mine and build a new Top of the line one.
All i have been able to decide on is:
Lian-Li Black Aluminum ATX Full Tower Case
AMD Athlon 64 FX55 proc
ASUS A8N-SLI Deluxe mobo
SILVERSTONETEK 650w Sli ready Psu
I know i want to have a pci-e videocard but im still not sure how sli tech works. I would also like to know your personal thoughts on how much ram is too much :). For HDs I was thinking of two 74GB WD raptors in raid 0 but that again is up in the air.... :?
any and all oppinions welcome....I need Help!
PostPosted: Thu Mar 17, 2005 10:25 am
And budget constraints?
If not.....
Then 2 gigs 'o RAM, 2 6800 Ultras, two 74GB raptors and another 2 300GB Diamond Max 10's oughta do it :D
PostPosted: Thu Mar 17, 2005 10:45 am
no problem with paying for it all. :P
only 2 gigs of ram? why not more?
why 2 6800 ultra's? i need to know more about sli tech!!!
and why the 2 300GB HDs?? are they good?
thank you again for the help!:)
PostPosted: Thu Mar 17, 2005 2:16 pm
2 gigs of ram is alot...and if you have more it probably wont get used. if you went with 4 gigs you would most likely go through 2 or 3 processor changes before 4 gigs is mainstream.
2 ultras because that is currently the fastest video setup you can get. sli works by putting 2 of the same card next to each other and having a chip bridge the 2 together and each card renders half the screen then puts the image together before it gets to your monitor.
and i believe the HD's that are being talked about are the maxtor drives with the 16mb cache. they are currently the fastest large capacity drives you can get. and 2 of them cause you want a wicked system.
as for the proc...wait for the FX-57 to come out i think it will be out very soon but im not exactly sure when.
PostPosted: Thu Mar 17, 2005 4:10 pm
I'm hearing alot of people saying that the 250 or 300Gb Maxtors http://www.newegg.com/app/ViewProductDesc.asp?description=22-140-153&depa=1 Have simular performance as the raptors due to its 16 Mb buffer.
PostPosted: Thu Mar 17, 2005 5:30 pm
Are you actually doing this? When would be a factor, because of the newer stuff coming out. Also, what do you do to pay for it! Can I have a loan? :lol: :wink:
PostPosted: Thu Mar 17, 2005 5:45 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
how many slots?? 4 gigs o ram :shock:
PostPosted: Thu Mar 17, 2005 7:23 pm
on gamespot.com the benchmarks show that the MSI sli board performs better with Half life2 and doom3, oh and 3dmarks than the asus mobo it has onboard soundblaster live 7.1 sourround or something like that. um check it out
btw does anyone else have any links like this for the SLI mobos that are out?
PostPosted: Thu Mar 17, 2005 7:41 pm
Just get two sticks of 1GB each for now. which gives you two slots to add some ram later. the Maxtor Diamondmax 10's at 300gb are good, get those.
PostPosted: Thu Mar 17, 2005 7:53 pm
wil there be a huge difference if i wait for the fx57 proc???. i already bought the asus mobo so that cant change and also go tthe case and psu. when can i expect the FX 57 to be released?????? im looking into the maxtor HDs right now. anyone have any info on the new X850 videocards vs the 6800s?
thx for the help
Edit: on the newegg site they list the seek time on the raptors as 4.5ms and the maxtors at 9ms. isent this quite a large difference????
PostPosted: Thu Mar 17, 2005 8:30 pm
Ok if money isnt an a factor in what your getting then I suggest this......
Seagate 73GB 15,000RPM SCSI (seek time 3.4 secs) but that will cost you $541 each. However I wouldnt spend the money on that, I would go for the 2 raptors it is definitly faster than the 300gb HD.
PostPosted: Fri Mar 18, 2005 1:24 am
better off getting the x800XT the x850 is LOUD AND HUGE sounds like a leafblower! :shock:
PostPosted: Fri Mar 18, 2005 2:16 am
Folding Momerator
Folding Momerator
If tech support matters to you, you may want to rethink the mobo. A lot of Asus's tech support section of their web site has been down for the last few weeks. While it's possible you won't need it, it's also possible you will. Before making a decision, you should use their site to try to get help for a problem, just to see if it's working.
PostPosted: Fri Mar 18, 2005 5:10 am
he already bought the motherboard. go with the dual 6800 ultras, ATI pales in comparison, and they also have no sli solution.
Contributing Writer
Contributing Writer
If you start playing the 'waiting game,' you'll never stop. There's always something seemingly right around the corner.
As for the x850XT PE, it's the fastest single card solution available today. To address Around_the_Fur's comments, the leaf blower comment is misleading. The card is loud when you first turn on your computer, and then the fan slows way down. When testing/stressing the card, MaximumPC was never able to get it to blow at full blast again, and this is consistent with other online reviews.
For the fastest gaming solution, you'd need to switch back to nVidia and go with 2x6800 Ultras (dependant on the game, of course).
Naturally, all of this represents some heavy overkill but it sounds like that's the direction you'd like to take. We'll be happy to accomodate, however for the best recommendations it would helpful to know exactly what you plan on doing with your computer (mainly gaming, photo editing, etc).
PostPosted: Fri Mar 18, 2005 5:28 am
First of all, ditch the ASUS board...DFI is the way to go. Second, RAID0 is way overhyped, if you have to do RAID, go RAID5 or 10. I'd also recommend the Maxtor DM10 over the WD Raptor, the difference in performance isn't that much, and the price and pure capacity really makes the Maxtor a better deal.
As to the FX57, moving to 90nm should make it a much better O/Cer, on top of being 2.8GHz, 90nm will definitely have better thermal properties......hold out for a month, it should start being released around the 5th to 10th of April.
PostPosted: Fri Mar 18, 2005 5:31 am
As to the FX57, moving to 90nm should make it a much better O/Cer, on top of being 2.8GHz, 90nm will definitely have better thermal properties......hold out for a month, it should start being eleased around the 5th to 10th of April.
first of all, HE ALREADY HAS THE ASUS MOTHERBOARD!! he isnt going to buy another one, the asus is a good board, there may be better, but that does not diminish the fact that the Asus is a good board.
PostPosted: Fri Mar 18, 2005 5:50 am
Jesus Christ...what is it with some people on this board????
where does it say he already has an ASUS board? He only says it is one of the things he has decided on, not that he has it....dude, chill out, maybe get laid, lay off the caffiene...I don't know.
PostPosted: Fri Mar 18, 2005 6:13 am
Contributing Writer
Contributing Writer
10th post down, I almost missed it myself.
I concur with the RAID 0 and Diamondmax 10, which is why I want to know what he plans on using his rig for. I also would have chosen a different mobo, but no biggie if he already has it.
PostPosted: Fri Mar 18, 2005 6:21 am
my bad...didn't see it....but still....all buds must chill.
I'm not a big RAID fan....I'd simply go with the DM10 or a 400GB Hitachi, another very good brand.
