It is currently Sun May 19, 2013 8:53 am
 Post subject: Compatibility issues/Choice of hardware on new build.
PostPosted: Mon Apr 16, 2012 1:21 am
I've never built a PC before, I decided to have a friend that knows how to build computers build me one. I am a firm believer in "trust but verify" so I just want to make sure I'm getting the best for my money and that when it all comes in it should be compatible. I'll be having another friend help me out with the actual building.
Case
http://www.newegg.com/Product/Product.a ... 6811119160
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Computer Case with USB 3.0, Black Interior and Four Fans-1x 230mm front RED LED fan, 1x 140mm rear fan, 1x 230mm top fan, and 1x 230mm side fan
Hard Drive
http://www.newegg.com/Product/Product.a ... 6822136697
Western Digital RE4 WD5003ABYX 500GB 7200 RPM 64MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Motherboard
http://www.newegg.com/Product/Product.a ... 6813131736
ASUS Sabertooth 990FX AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
Processor
http://www.newegg.com/Product/Product.a ... 6819103960
AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8150FRGUBOX
RAM x2
http://www.newegg.com/Product/Product.a ... 6820231527
G.SKILL Ripjaws X Series 8GB 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL10S-8GBXL
Power supply
http://www.newegg.com/Product/Product.a ... 6817814019
ABS Majesty series MJ1100-M Continuous 1100W@50°C ATX12V/EPS12V 80 PLUS GOLD Certified, Single 12V Rail, Modular Flat Cable Design, Active-PFC "Compatible with Core i7, i5" Power Supply
Video Card x2
http://www.newegg.com/Product/Product.a ... 6814131464
PowerColor AX7850 2GBD5-2DH Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Thanks in advanced. Also if you have any other questions, I'll be checking on this thread from time to time.
 Post subject: Re: Compatibility issues/Choice of hardware on new build.
PostPosted: Mon Apr 16, 2012 10:02 am
You could tone down the PSU a bit to about 800W and save some money. But the rest is okay. The reason why I say this, if you're going on the video card box's "power supply requirement", they're assuming the worst case scenario (fully loaded system). A system like this with just one video card I can't see drawing more than 250W on full load. Adding another video card would just increase it to about 400W at worst case.
I like to use this to get a rough and dirty estimate: http://extreme.outervision.com/psucalculatorlite.jsp
Also if you're thinking about getting 16GB of RAM, you might want to reconsider. Only because if you're primary high-performance programs are games, you won't need more than even 4GB. 8GB is good enough for a while and I don't see this changing ever until video game devs start doing 64-bit executables. And if you want a reason for this, practically all games are 32-bit still. In Windows, 32-bit programs in a 64-bit environment default to having only 2GB of user space available to them. Some games are built so they can go all the way to 4GB (like Skyrim). But otherwise, since you can expect no more than 2GB of use, there's little point to adding more RAM past even 4GB. But 6GB-8GB makes for a nice comfort zone.
Users browsing this forum: Google Adsense [Bot] and 2 guests
