Alrighty, we'll try this WITHOUT linking to NEWEGG this time since my post got denied for "providing links to pirated software".
Just wanted to run this build by you guys to see if there is any issues you can see. A lot of this was put together off or reading/info I've gleaned off of this forum (Jbaz, Dantrhax, etc.)
Budget is sub $1000, although if I could get it to under $900 that'd be even better. Comp is mainly going to be used for gaming, casual use, etc. Max Resolution 1920x1080 & I already have a case (
ANTEC 900) & peripherals.
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz
Mobo: ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68
PSU: OCZ ModXStream Pro 700W Modular High Performance Power Supply
Video: MSI N560GTX-Ti Hawk GeForce GTX 560 Ti (Fermi) 1GB
Mem: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
HD: Samsung by Seagate Spinpoint F3 HD502HJ/ST500DM005 500GB
Optical: LG ELECTRONICS GH22NS90B
OS: Windows 7 Home Premium 64-BitAny thoughts? Anything that I should change, doesn't work, etc.? 700w PSU enough or too much? I like that Mobo just in case I wanted to add another card in down that line. May change the card to a
MSI R6870 Hawk Radeon HD 6870 1GB to save some money if needed.
CHEERS. & THANKS IN ADVANCE for any & all advice.
