It is currently Sat Jan 31, 2015 12:18 pm
 Post subject: Do you use a program to tell you the temp of your CPU?
PostPosted: Mon Jul 26, 2004 1:05 pm
Hey guys, I'm pretty new to all of this, how do you all seem to know what temperature your processor / chipset whatever it is is running at? Do you use a program for this? or did you set up something on the CPU / motherboard? If you use a program, which one? I would be curious to find out what my processor runs at.
Thanks in advance.
 Post subject: Re: Do you use a program to tell you the temp of your CPU?
PostPosted: Mon Jul 26, 2004 1:21 pm
Thanks in advance.
I use the software that comes with my motherboard. I would suggest checking out your mobos website and checking to see if they have a monitoring program. What type of mobo do you have?
PostPosted: Mon Jul 26, 2004 3:43 pm
I smell a poll.
MBM
Bay mounted monitor(digidoc,etc)
MFG software
finger
other
I use both MBM and the Enermax 2X2 Ultimate Controller.
PostPosted: Mon Jul 26, 2004 3:44 pm
i use the software that came with my motherboard.
PostPosted: Mon Jul 26, 2004 4:47 pm
I use MBM
I've read in many places that the temp monitor that comes with your mobo isn't always very accurate. I've heard that most about ASUS boards.
PostPosted: Mon Jul 26, 2004 6:38 pm
hm so what is MBM? =) *EDIT - nm I found it, Mobo monitor heh
And I really don't know which mobo I have, this is last prebuilt computer I'll own, I hate not knowing what video card / ram / mobo etc. I have.
*EDIT - ok found out my mobo is Intel D850 EM V2
PostPosted: Mon Jul 26, 2004 7:01 pm
Used to use a combination of thermistors and MBM. I still can't trust winbond too much:p I recently made a hardware change in the last system to an Abit AA8 and they have a dorky little "guru clock" in the 3rd eye series if that floats your boat.
http://www.abit-usa.com/images/guru-clock-500.jpg
PostPosted: Wed Aug 11, 2004 8:53 pm
I ran both MBM5, sadly, no longer being updated, and Asus probe (came with the MB) together. The readings agreed with each other (when they play nice).
When these two don't place nice (occassionally) you tend to get wild & unsubstantiated readings as I learned 1am one morning. An alarm goes off cause one tells me that the proc is running at 83C!!! Luckily I have an external probe and it was reading normal and the heat sink felt fine. For a moment there I thought I had a reason to upgrade :lol: .
PostPosted: Wed Aug 11, 2004 10:38 pm
yes, MBM5
sadly, it is no more (no more updates at least)
PostPosted: Sun Aug 15, 2004 9:09 pm
I use the program that came with my Asus mobo
PostPosted: Mon Aug 16, 2004 5:18 am
Ditto. ASUS Probe. Even lets you record a history so you can see if a certain program stresses your CPU too much.
PostPosted: Mon Aug 16, 2004 7:07 am
MBM5 and a homemade modded temp probe(car dash probe)
