It is currently Tue Jan 27, 2015 3:30 am
 Post subject: Need power supply buying ins & outs.
PostPosted: Mon Mar 14, 2005 11:36 am
I'd like to know all of the considerations to look at before deciding on a PSU. I know how to calculate needed Watts but most everything else is a gray area for me.
For example, Newegg has listed under the Compatible: drop-down list,
ATX 12V 1.2
ATX 2.03
ATX 2.03 & ATX 12V 1.1
ATX/BTX
etc.
I'm building a system for someone using a SOLTEK SL-K890Pro-939 and I'm really not sure what to buy. I usually buy Antec 400-500 Watt PSUs and do fine but I'd like to be a little more knowledgable.
PostPosted: Mon Mar 14, 2005 11:41 am
M-Powered
M-Powered
Read reviews and shootouts from reputable online sources. From stated positives and negatives you can get an idea about what’s important.
PostPosted: Mon Mar 14, 2005 1:03 pm
buy either the Antec Neopower, OCZ Modstream, or OCZ Powerstream and you will be 100% set.
PostPosted: Mon Mar 14, 2005 1:06 pm
Smithfield*
Smithfield*
OR antec truepower
PostPosted: Mon Mar 14, 2005 1:17 pm
gramaton cleric wrote:
OR antec truepower
not the current truepower line. they dont support all the new specs. once the truepower 2 line is in stores, then they will be good again.
 Post subject: Re: Need power supply buying ins & outs.
PostPosted: Mon Mar 14, 2005 6:26 pm
Celeron
Celeron
If you really want to be certain about the PSU, then the ATX 2.0X spec should be what you're aiming for, unless I'm mistaken. However, a PCI-E board should be safe with the older ATX 12V 1.2 spec if the supply is stable and powerful enough.
Antec 400-500W PSUs should definitely be able to handle it. Otherwise, I would go for the Enermax alternative.
