It is currently Sun Jan 25, 2015 9:48 pm
 Post subject: final part list for a freinds computer
PostPosted: Sun Mar 13, 2005 2:27 pm
whadaya think?
athlon 64 3000+ 90nm socket 939-----------------------------------$129
DFI Lanparty SLI-DR $151
Crucial Ballistix 512mb 2-2-2-5 timings!!!---------------------------$110
Hitachi SATAII 80gb 7200rpm 8mb $62
MSI 6600gt 128mb-----------------------------------------------------$185
MGE viper case w/500w PSU $75
NEC ND-3520A DVD burner-------------------------------------------$57
thermalright xp-120 w/Delta 120x38mm fan 220cfm:shock: $43+27 for fan
3x masscool 80mm fans $4
total----------------------------------------------------------------------$897
I'm tring to get it down to about $825 so if snyone can find any of these parts cheaper tell me plz.
PostPosted: Sun Mar 13, 2005 2:39 pm
i would get another 512mb stick, sata isnt sensitve at all to ocing. other then thats its all good.
PostPosted: Sun Mar 13, 2005 2:44 pm
It is if the fsb locks aren't working.
PostPosted: Sun Mar 13, 2005 6:33 pm
if i lock the fsb then how would i overclock the multiplier is locked?
PostPosted: Sun Mar 13, 2005 10:56 pm
Make sure to buy a new PSU. Unless it is a namebrand PSU that comes with the case.
 Post subject: Re: final part list for a freinds computer
PostPosted: Mon Mar 14, 2005 3:51 am
Folding Momerator
Folding Momerator
dunn2953 wrote:
whadaya think?
ASUS A8N-SLI-Deluxe $151
If tech support is important to you, you may want to reconsider the mobo. Go over to Asus and look at the mobo page, then try to find answers to a problem (say no boot issue). Last 2 weeks that I have been there, most of the support site was down.
A few posts from here-
Need help! Won't boot.
ASUS A8N-SLI Deluxe Beeping problem
Asus A8N-SLI Deluxe
Reboots During initial install- not your board but you'll see how I tried to get support at Asus and kept running into walls.
I would also check google advanced for reviews of the board, and also use "problems" or "issues" as search terms; to see if others are having issues with this board.
PostPosted: Mon Mar 14, 2005 3:39 pm
he is the type of person who wouldn't call tech support if his life depended on it...dosen't know shit about computers but thinks he does...before i told him to just pay and i'd deal with the rest he was going to get a dell...{i scream in agony}
PostPosted: Mon Mar 14, 2005 3:45 pm
changed heatsink to a thermalright xp-120 with the ultimate fan a delta 120mm extreme high speed. this baby gets 220cfm and its nice and quiet too only 65 dBA!!!
PostPosted: Mon Mar 14, 2005 5:07 pm
Folding Momerator
Folding Momerator
So what will you do if you can't get support for his board?
PostPosted: Mon Mar 14, 2005 5:31 pm
post it in forums until i get an answer/3 year warrenty
PostPosted: Tue Mar 15, 2005 5:49 pm
i just looked at the asus web site and jeez how can a top teir company get away with that :( i changed the motherboard to a DFI SLI-DR and am looking to shave some money off the price any suggestions?
