It is currently Wed May 22, 2013 11:39 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 127 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
 Post subject: Re: Critique my $900 budget build please
PostPosted: Tue Mar 13, 2012 6:51 pm
Quote:
Posting anything that is off topic and posting stuff like the following IS trolling. I posted the definition earlier if you need to read it.
"with trolling, its describing intentionally provocative actions and harassment outside of an online context."
Quote:
There is a wide side of the radiator where the fan(s) are mounted and a narrow side of the radiator where the fans are not mounted. Look on page 2 and 3 if you need to see a picture of the 212+.
WTF... That's not even what the fuck I'm talking about. I'm talking about the orientation/direction of how you mount the heatsink onto the cpu... With the fan, there's only four possibilities of how you orient the heatsink and fan.
Quote:
I never said "ALL".
The sentence structure of your statement dictates this. It's called deductive reasoning using an IF THEN statement.
Break it down: IF "In new cases..." and your resulting THEN "it won't matter"; the logical conclusion will be that "In new cases, it won't matter". You did not bound the statement to any set of parameters or conditions using adjectives, so logic dictates that its ALL or NONE for the statement to be valid. It only takes one invalid of either premise to invalid the clause/conclusion.
"it won't matter..." what doesn't matter? "In new cases...".
With that, what about the statement: "it does matter...", then logic dictates with your statement that it can't be a new case. If it is, then its invalids your claim.
This can also be classified as a sort of logical fallacy as the statement is an improper argumentation in reasoning resulting in misconception or presumption as the sentence structure is classified as informal.
PostPosted: Tue Mar 13, 2012 8:35 pm
Danthrax66 wrote:
I never disagreed with JBaz I just explained it differently/incorrectly. Also: Scumbag OP - takes our advice for his build because he doesn't know what to do... Questions us when we tell him mounting his heatsink a different way is more efficient.
Nuff said.
On an unrelated note should I get this http://doublehelixcables.com/store/inde ... ucts_id=56 or this http://doublehelixcables.com/store/inde ... ducts_id=2
I knew what to do. I just asked for advice on what to buy.
You explained a LOT of things incorrectly. And you never correctly explained why the 212+ should be oriented the other way. Only thing I read was something about someone getting Corsair to change their water cooling instructions. Then you went on to name calling because you couldn't prove your point. And apparently still are.
And if you are buying those cables, then you really don't know anything about audio cables. Actually, you should go buy those and waste your money. Get yourself some Monster Cables too.
Again, start reading and stop ranting. That's what I was talking about that you didn't read before.
JBaz wrote:
Quote:
I never said "ALL".
Yours wasn't a new case. Yours is a modified case with fans were there was not intended any to be in the original design. Therefore, the statement doesn't apply to your case.
PostPosted: Wed Mar 14, 2012 7:01 am
YOU may have started talking about this "narrow" side bullshit that's frankly to stupid to even think about because no one knew what the fuck you were talking about. Narrow what?!?!? There's only 4 POSSIBLE ways to mount your cpu cooler... ALL four ways will work in cooling down your cpu... ALL four ways will still radiate heat once the system is turned off. Heatsink orientation does not apply to efficiency once the system is off and in passive form.
Explain to me again how you think this heat rises shit works again with the narrow side and shit?!?!
How do you know? Your ASSUMING that my case isn't new or can' be bought as new. Your ASSUMPTION is where you are getting into problems and still not binding the statement to any set of parameters or conditions using adjectives.
How do you know my case didn't have indented fan slots in the optical drive slots? Again, you are ASSUMING.
Even if they weren't designed, you did not bound your argument in saying stock or modified cases. The original sentence structure still oriented in an ALL or NONE logic set. "in new cases", What about modifying the new cases? would it still matter? But since you didn't set any parameters, its still a simple no, "it won't matter". It only takes one truth to invalid your original rhetoric.
What defines modify? Does adding a case fan consider modification, even if its part of the original design? Even then, what defines new? What if the design is old, but can still be purchased at a retailer, is it still considered new? What if the new case is actually just a modified old design? Then couldn't you say that all ATX cases are based on the AT standards from the 1990's, 1980's and even older?
PostPosted: Wed Mar 14, 2012 8:17 am
Tox also committed a logical fallacy in there.
PostPosted: Wed Mar 14, 2012 9:30 am
Yes... yes he did... lol :wink:
PostPosted: Wed Mar 14, 2012 12:52 pm
I will dumb it down even more for you.
YOU said:
JBaz wrote:
What I think you were referring to was how much "better" your cpu cooler would radiate heat when the PC was off... When in fact it will radiate heat just the same in any position.
So according to YOU, the radiator will radiate heat "just the same", in ANY position. That means EXACTLY the same heat dissipation regardless of position. IF "any position", THEN radiate heat "the same".
The 212+ has a wide side where the fans mount, right? and there is a narrow side where the fans are now mounted, right? You have seen one of these before and paid enough attention to them to see that they are not a perfect cube? One side is wider than the other. Do you understand that much so far? You haven't understood that much before this post so I am making it clear for you.
I then said, if that were true, then the fan, which is normally mounted on the wide side of the radiator, could be mounted on the narrow side of the radiator (remember, it's not a cube), and it would cool "just the same". And that is not true. The fan speed is the relatively same. The ability to cool at the same rate is NOT the same.
You said you mounted the fan in the 5.25" drive bays. You said "in the 5.25" drive bays". If they are "in the 5.25" drive bays", then they are not mounted to indented fan slots. Drive bays are designed for drives, not fans. I didn't need to assume that your case wasn't designed for it. You already stated that fact.
JBaz wrote:
In my setup, I actually have two fans in the 5.25" drive bays pulling air in from the outside directly to my cpu cooler and have seen a 1-2C difference.
PostPosted: Wed Mar 14, 2012 1:51 pm
Monkey Federation (Top 10)*
This is why we can't have nice things.
