It is currently Tue Apr 28, 2015 3:42 am
 Post subject: Does sempron work in nforce2?
PostPosted: Fri Mar 11, 2005 2:43 pm
Ok, my question is this: will an AMD Sempron 2400+ work in an Asus A7N8X-X nForce2-400 motherboard? Thanks for the help.
PostPosted: Sat Mar 12, 2005 7:27 am
depends, none of my amd mothers will take a semp. even the motherboard that came with the cpu isnt capable without a bios update. hows that for a combo deal.
check on the asus site for a bios update with sempron support. or which bios you need. 1010 has sempron support
http://www.asus.com/support/cpusupport/cpusupport.aspx
