It is currently Sat Apr 25, 2015 2:10 pm
 Post subject: Building a System---need critisim
PostPosted: Fri Mar 11, 2005 4:21 am
My friend is looking to build a system for $1000. I have read the thread below and used that to put together the following. (he is reusing his old case, monitor, keyboard/mouse)
http://secure.newegg.com/app/WishHistoryReview.asp?position=HISTORY&submit=VIEW&ID=1382747
Any critisim and/or advice would be greatly appreciated!! Thanks in advance :D
PostPosted: Fri Mar 11, 2005 4:39 am
Chief Surgeon
Chief Surgeon
Your motherboard and processor aren't compatible.
Mobo uses Socket 939.
Processor listed is Socket 754.
You can use this one.
SC64
PostPosted: Fri Mar 11, 2005 10:43 am
What Size is his PSU if it is not at least 400w will probably need a new one other than that (and what SuperChips posted ) looks good
PostPosted: Fri Mar 11, 2005 11:41 am
For about $20-30 more, you can get a MaxDiamond 10 250GB drive which has a 16MB buffer.
Again with a PSU that is above 400watts. Look into an Enermax.
Get the 3200+ that has the Winchester core (90nm). Gives off less heat than the Newcastle, and the price is about the same.
PostPosted: Fri Mar 11, 2005 2:45 pm
Chief Surgeon
Chief Surgeon
That's what I had linked him.
Please fully read the posts, and the attendant links. Thanks.
SC64
PostPosted: Fri Mar 11, 2005 2:56 pm
Wasted that much time to denounce a second recommendation for that product? Strange. Sorry for making the same recommendation and giving an explanation of why it's a better product.
