It is currently Sat Apr 18, 2015 1:51 pm
 Post subject: PCI problems
PostPosted: Thu Mar 10, 2005 10:18 pm
So I finally built my first computer, and it went off without a hitch.......well, almost. My MoBo is not recognizing any of the PCI cards, so I cant connect to the internet, or use my soundblaster audigy 2 for sound output. Anyone know whats going on? My mobo is Asus A8V K8T800 pro. Anyone have any similar problems or know how i ocld fix this? Thanks,
Ink
P.s. Thanks to everyone here who helped me get this far, you've all been a tremendous help.
PostPosted: Thu Mar 10, 2005 10:56 pm
What pci express card did u get?
PostPosted: Fri Mar 11, 2005 5:36 am
heh, not PCI-E, just plain old PCI
PostPosted: Fri Mar 11, 2005 9:43 am
I think there might be drivers that are on the motherboards CD that might need to be installed. If I am wrong someone correct me.
PostPosted: Fri Mar 11, 2005 10:12 am
King of All Voodoo2 Cards
Did you install the chipset drivers?
PostPosted: Fri Mar 11, 2005 5:03 pm
Yes, all of my drivers are installed, but i tried installing the drivers for the WLAN card, and it doesnt do anything at all. The driver for the SB Audigy 2zs on the other hand, says that windows cannot find start.exe. I would try downloading SP1 and SP2, but its kinda hard to do that without the WLAN card up and running :&.
PostPosted: Fri Mar 11, 2005 5:16 pm
Folding Momerator
Folding Momerator
when you say it doesn't do anything at all, do you mean it doesn't install the drivers, or it installs the drivers but the it still doesn't work? Are you sure everything is enabled in the bios?
Keep the sound blaster out and anything else that is not necessary until the board is up & running correctly.
PostPosted: Fri Mar 11, 2005 5:24 pm
Install shield says that it successfully installed the drivers, and The D-Link air utillity gets intalled, but the device manager says that the drivers arent installed for it, and when I try to run the Air Utility, the system tray Icon does not show. I had the Sound Card in there to make sure that it there wasnt somthing wrong with the actuall motherboard. I thought maybe there was somthing wrong with the PCI ports, but im just all around confused.
Edit.....by the way, the LEDs on the WLan card arent lighting up, is my card dead? Device manager recognizes that it is an Ethernet Controller, but maybe it was damaged by static electricity?
PostPosted: Fri Mar 11, 2005 9:51 pm
Hmm.. the only thing I can come to is that some part of your mobo is damaged.
