It is currently Mon Apr 20, 2015 11:26 pm
 Post subject: ASUS N6600/TD 256MB AGP Overclocking
PostPosted: Thu Mar 10, 2005 11:47 am
Does anybody have an idea on how far these puppies can be overclocked, or about volt mods, It's the 6600 non GT. So far its running @ 27 degrees celcius and the core's overclocked by 200mhz!. i dunno how much farther i can push it!
PostPosted: Thu Mar 10, 2005 6:26 pm
Cripes, that's some o/c. What are you doing with the memory?
If it's not locking up, and you don't see any artifacting, great job.
PostPosted: Fri Mar 11, 2005 7:48 am
right now, my asus ic oc'd from 300 core, 500 mem (1 ghz effective)
to 600 core, 550 mem (1.1 ghz effecitve)
i think the core will go somewhere between, 650 and 700.
the highest temp ive gotten on the core is under 40 degrees celcius. 35 for the mem.
oh, did i mention it's the stock heatsink...
probably because i modded my case to reverse atx/btx, 120mm fan pushes air onto card from front of case
Here's the problem... i cant find an overclocking program that will go past 600mhz core.
Any suggestions?
PostPosted: Sat Mar 12, 2005 4:03 pm
I dont know about a software program but you if you do find some you could change the stock HSF to something like Zalman or Artic Cooling.
I dont know the specs of either of the heatsinks but you could also put RAM sinks on, if they fit, which I dont think they would with those aftermoarket heatsinks.
But good job none the less.
PostPosted: Sat Mar 12, 2005 9:24 pm
Celeron
Celeron
Any suggestions?
Wow, you MUST be kidding, right? Is your PC sitting somewhere really freakin' cold?
I'm skeptical: how could you have doubled the core speed?
By the way, the stock speeds on 6600's are 500MHz effective.
PostPosted: Sat Mar 12, 2005 11:01 pm
if your having problems with programs not going over 600, you could consider flashing the BIOS with one from a later card. i know with Radlinker for my ATi card i can change the Mhz that i move up or down, and if i do that i can set the core to 3440Mhz, which would probally kill it instantly lol
PostPosted: Mon Mar 14, 2005 6:21 am
The clock speeds on the asus is racheted down to 300. oh yeah, now running at 600/600 (1.2ghz effective) mem won't go any farther without sinks, but found way to overclock higher with rivatuner...
Will keep you posted...
oh yeah, also got a barton 2400+ oc'ed from 2000 to 2350-2400ish
oh, and im getting one of the zalman's, artic cooling doesn't have a heatsink for the agp version yet
PostPosted: Tue Mar 15, 2005 6:04 am
sorry for the double post, but go here to see a picture of my overclock. www.geocities.com/masterngc/proof.html
