It is currently Sun May 19, 2013 1:28 pm
 Post subject: Laptop Help
PostPosted: Thu Feb 02, 2012 7:47 am
Hey guys,
I currently have a Dell M1210 Laptop. It is starting to really lag and make some very loud fan noises. I have done my best to keep it clean and running well, but it seems to not just be up to snuff any more. It was a great unit and I was able to use it for almost 6 years. I am now wanting a new laptop but the market seems so confusing!
The unit is mostly for school, which entails, matlab programming, processing data, storing large files. I am thinking I want to give priority to processing power and storage. Graphics are less in demand for me, I rarely watch video on the unit. I was hoping to spend around 1000-1200 Can$. No bigger than 13-14 inches, and a long battery life would be good. I never use the unit outside so a screen that is capable of that is not needed.
I was checking out Dell, Sony, Lenovo, but it seems that when you increase storage and CPU, you alos have to pay for increase in video.
Does anyone have any suggestions, I am getting very confused.
Phad
 Post subject: Re: Laptop Help
PostPosted: Thu Feb 09, 2012 2:49 am
Team Member*
Team Member*
Buy for the CPU and add HDD space yourself it would probably be cheaper any way.
PostPosted: Thu Feb 09, 2012 4:14 am
Asus Zenbook 13.3" UX31E-DH52 ultrabook. $1100 @ newegg.ca...
    Intel Core i5-2557M 1.7GHz 3MB L3 Cache
    13.3" 1600 x 900 LED backlit
    4GB DDR3 1333
    128GB SSD
    802.11b/g/n Wireless LAN
    Bluetooth v4
    3 lbs, 2.1 oz
    Up to 7 Hours
MPC Zenbook Review (Link). The biggest down size is that it only has a 128GB SSD and you can't replace the drive, but if you want something light to throw around and be powerful, its a good PC for it. Add some small 2.5" usb storage drives and you should be good.
PostPosted: Thu Feb 09, 2012 7:57 am
This is one I have been looking at for sure. It is on the low end of the cost I was looking at and it is getting super reviews.
Any thoughts on the Lenovo x220?
Phad
PostPosted: Thu Feb 09, 2012 8:25 am
If I had the money, I would totally go for an x220t with the 6 cell slice battery. You'd get 20+ hours of continuous use in a fairly compact body. One of the main down side is that it'll be a bit hard to handle in tablet form for all day use, but honestly, people should grow a pair.
Also, like the ultrabooks, it uses Intel's HD gpu core so don't expect to play high end games; that's probably my biggest beef with the x220's besides the 1366x768 resolution lcd. If it had a discrete card, nothing crazy mind you, I would have purchased one last year.
You can cheap out and get the regular x220 non-tablet version for $250 less, but the zenbook is pretty much just as feature rich in other aspects for the same size laptop.
PostPosted: Thu Feb 09, 2012 2:07 pm
It looks like some of these might be going on sale as the models are replaced in the next little while.
Then i just have to convince myself that I do not need the new one!
Phad
PostPosted: Fri Feb 10, 2012 6:49 am
phaddie wrote:
Hey guys,
Phad
You can find a i5 or i3 with without a discrete graphics card fior between 400 and 700 that should work for you.
PostPosted: Fri Feb 10, 2012 8:02 am
^not in a 13" or 14" chassis. 13" i5's start around 700-800. You can find a few 14" i5's in the 600 price range, but most are still 700 and up.
