It is currently Thu Mar 05, 2015 8:50 am
 Post subject: 2500+ M
PostPosted: Wed Mar 09, 2005 3:16 pm
Hi all. I have a quick qc question. I have a 2500 XP on an Asus A7N8X-E Deluxe, 512 mb, MSI Ge Force 5700. My psu is an Elements 380 watt. My voltages look fine according to some other posts I have read. When I try to up the fsb to 200, I get the blue screen, so I change it back and everything is fine. I can change the multiplier up to 12.5 before it won't post. Am I stupid or is this a common problem. The 2500 is an Athlon M that I got by mistake from newegg. I ordered anoem 2500+ Barton but cpu-z states that it is a Mobile Athlon(v}90{P-M. Are these oc-able? I really don't need to oc this I was just trying it to see what happened. Thanks
PostPosted: Wed Mar 09, 2005 8:22 pm
hello
i don't know if it is common but i have a 2600XP-M that ca not hit 200 (stable) anyway.... i'm not quite sure why could be ram/PSU/motherboard or the Chip itself but if i go for 200 on my 2600XP it gets prime95 errors.
since i just got a 3200XP athlon64 for xmas which is now my main pc, it decided not to worry about it and just run the 2600 @ 2Ghz 166x12 and call it a day :D
