It is currently Mon May 04, 2015 12:13 pm
 Post subject: building a system - needs advice
PostPosted: Tue Mar 08, 2005 7:53 pm
I'll soon build my own machine and I'm still debating whether I should go with a P4 motherboard w/ an ATI card or whether I should go w/ an Athlon w/ 2 nVidia cards in SLI.
I'm mainly going to use the machine for content creation, particularly digital photo and video editing, and secondarily for gaming.
PostPosted: Tue Mar 08, 2005 8:22 pm
if you're doing photo and video mainly, i'd check out the p4, in most benchmarks the p4 takes the lead. Check for benches on the relevant program you plan to use.
If you're going mostly editing, going dual cpu would benefit you more so than dual video cards. Xeons or opterons, just look for benches in software you're planning to use.
high powered cards can easily play todays games at 1280x1024 or 1600x1200 with most if not all quality options on.
If you're budgeting, for $200, the 6600gt, for $300, the ati x800xl, i wont bother mention the gt at 400 because it's about on par with the 800xl and $100 more. then you have the really high end stuff, which isn't going to make too big a difference over the xl. If you have to get the best of the best though, the x850xt..
edit - damn, ati bumped the price to $350
PostPosted: Wed Mar 09, 2005 8:10 am
i second the P4 since it leans towards multimedia more. get plenty of ram too.
PostPosted: Wed Mar 09, 2005 12:20 pm
This would be my first custom-build on my own; I don't think I'm ready to build a dual-Xeon system.
Besides, I'm trying to keep my total costs (incl. monitor) under $3500, under $3000 so long as I can maximize every dollar.
PostPosted: Sun Mar 13, 2005 3:29 pm
would u ever consider getting P4 Extreme Edition or HT?
Users browsing this forum: Cyberdiver, justbeast123 and 6 guests
