It is currently Mon Mar 02, 2015 11:34 am
 Post subject: 2500+ Barton at 209FSB and locked 11x multi randomly reboots
PostPosted: Mon Mar 07, 2005 1:22 pm
Max [Ph]otographer
Max [Ph]otographer
Hey all.
I have had this thing overclocked for a long time now, probably over 6 months, but recently it's been having problems.
It all started with HL2. The game would play fine for a while and then the machine would randomly reboot. This was last January.
Over time those once-a-week-while-playing-HL2 reboots became more common.
Recently I brought the FSB up from 200 to 209, and the problems grew worse.
I'm thinking that I have a bad PSU. My PSU is a generic 520watt.
Here are my voltages as seen in PC Wizard 2004:
Vcore: 1.68 V
Vcore1: 2.85 V
+3.3V: 3.34 V
+5V: 5.11V
+12V: 11.8V
They look fine to me, and they have been pretty stable. Other than that I don't know what the problem could be.
Oh, and one more thing, it seems my Abit NF7-S won't go any higher in the FSB than 209mhz, even though it allows me to select 210, it won't actually use 210.
Dan O.
PostPosted: Mon Mar 07, 2005 1:27 pm
Contributing Writer
Contributing Writer
Belboz, have you checked for a heat issue? You fold 24/7 on this rig, correct? It may be time to dust out the fans, clean off the heatsink and CPU, and reapply some Arctic Silver 5.
Are the reboots only occuring in HL2 or are there any other symptoms? Checked your event logs?
PostPosted: Mon Mar 07, 2005 1:34 pm
Max [Ph]otographer
Max [Ph]otographer
One4yu2c, I don't think it's a heat issue. The highest the temps have gone is 48C, most people say that to keep an XP stable during an oc you need to keep it below 55C.
I clean the fans and HSF regularly, in fact, I just did it last January.
The reboots are no longer just HL2, though HL2 is when they first started to appear.
I've got this at 208mhz FSB now, and it hasn't rebooted in the hour that it's been up, but at 209mhz FSB it rebooted twice in 2 hours.
Where's that setting to show the blue screen instead of automatically rebooting? Perhaps I can narrow down the cause by setting that option.
Thanks,
Dan O.
PostPosted: Mon Mar 07, 2005 1:40 pm
Contributing Writer
Contributing Writer
- Right click My Computer and select Properties
- Advanced tab
- Under Startup and Recovery, click on Settings
- Under System Failure, uncheck Automatically Restart
Check your event logs as well. Click Start, Run, and type eventvwr.msc and it will take you right there.
Finally, it would be worth running Memtest86 to see if your RAM has simply crapped out on you. And of course, it certainly wouldn't hurt to invest in a quality PSU as planned, regardless of whether it turns out to be the culprit or not.
PostPosted: Mon Mar 07, 2005 2:45 pm
Max [Ph]otographer
Max [Ph]otographer
- Advanced tab
Okay, I changed the setting.
I can't find any error logs that describe my problem.
I ran Memtest a couple days ago for 2 passes with 0 errors.
Yeah, I plan on getting new PSU as soon as I get a job.
Edit: And oh yeah, FAH borked on me, luckily I had a backup.
Thanks,
Dan O.
PostPosted: Mon Mar 07, 2005 3:58 pm
Celeron
Celeron
Thanks,
Dan O.
More passes. Try a couple of hours.
PostPosted: Mon Mar 07, 2005 4:19 pm
Contributing Writer
Contributing Writer
Well, shoulda got a Northwood... :lol:
PostPosted: Mon Mar 07, 2005 4:34 pm
Smithfield*
Smithfield*
ever think your poor old dog 2500+ has had enough of an overclock at 100% usage for an eternity of time in pc terms. just to leave it running non stop at 100% for a long time is rough, but with an OC as well? is there any documentation on the long-temr effects of folding. is anyone still folding with a p2 that they's had going non-stop since its purchase as a new proc? i'd say your processor could be burnt out. can ou pop it out and look at it? are those little valley things on the outside browm or green part of the cpu a little black around the edges?
PostPosted: Mon Mar 07, 2005 4:41 pm
Contributing Writer
Contributing Writer
What Gramaton Cleric is saying is that Intel makes a stronger chip, especially when it comes to handling games - see, shoulda gone with a Northwood. :P
Somebody pass me a cold one as I wait for a catch...
PostPosted: Mon Mar 07, 2005 6:14 pm
i had an asus board and it HATED to go over 209 FSB, my Epox 8RDA6+ Pro is sitting @ 220FSB rock solid. and i think my Asus board had the same chipset as your abit board, the epox's is a little different
PostPosted: Tue Mar 08, 2005 8:32 pm
Max [Ph]otographer
Max [Ph]otographer
Hey guys, I think I might have an answer to the riddle.
About 6 months ago my northbridge fan started making a lot of noise, so I unplugged it.
I still haven't replaced the damn thing. :lol:
Dan O.
PostPosted: Wed Mar 09, 2005 4:50 am
Smithfield*
Smithfield*
:lol: , think you could pass me a cold one.
Dan O.
:lol: well that would do it you tard :roll: put a big cpu cooler on it so you can overclock to like 3ghz
PostPosted: Wed Mar 09, 2005 6:41 am
Max [Ph]otographer
Max [Ph]otographer
Man, it's gonna cost me $15 to replace that damn thing. That's not in my budget right now. :(
Of course, I think I just might get this job today. :D
Dan O.
PostPosted: Wed Mar 09, 2005 7:41 am
Contributing Writer
Contributing Writer
Put ice cubes on it as a temporary solution ;)
PostPosted: Wed Mar 09, 2005 9:29 am
Dan O.
I bought a chipset cooler pack from CompUSA for 10 bucks... it had 2 heat sinks (north and south bridge I assume) and a cooling fan that would fit the northbridge (i think, the holes that were predrilled on my mobo were not far enough apart) it did fit my GeForce 2 perfectly though.
