It is currently Mon Mar 30, 2015 1:07 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
Have you taken the 64-bit plunge?
Yes 37%  37%  [ 7 ]
No 63%  63%  [ 12 ]
Total votes : 19
 Post subject: 64-bit Plunge
PostPosted: Sun Mar 06, 2005 1:57 pm
I've decided to take the 64-bit plunge. I'm looking for a mobo + cpu. I can only spend a max of 400 bucks. I was looking at the Gigabyte GAK8VT800 and ATHLON 64 2800+. Or is there something better out there for under $400?
PostPosted: Sun Mar 06, 2005 3:21 pm
I got a socket 754 asus k8n and 2800+ for $225.
PostPosted: Sun Mar 06, 2005 3:25 pm
i didn't take it to get 64-bit capabilities, i wanted a good gaming comp and athlon 64 kicks ass in benches
newegg.com prices
ECS "KN1 Extreme" NVIDIA nForce4 Ultra Chipset Motherboard For AMD Socket 939 CPU -RETAIL
$105
AMD Athlon 64 3000+, 512KB L2 Cache, Socket 939 64-bit Processor - Retail
$155
total $260
this mobo seems awsome it has dual gigabit lan, PCIe, 4 SATAII and 2 SATA headers, and look at the cooling solution.
PostPosted: Sun Mar 06, 2005 4:52 pm
does the K8N need registered RAM?
PostPosted: Sun Mar 06, 2005 5:00 pm
Celeron
Celeron
Nope.
Remember: Only s940 processors require Registered RAM.
PostPosted: Sun Mar 06, 2005 5:49 pm
do you have an agp vid card or pcie? if agp you cant get the nforce 4...
PostPosted: Sun Mar 06, 2005 6:00 pm
M-Powered
M-Powered
By 64bit plunge, do you mean having a 64bit processor run 32bit code?
PostPosted: Sun Mar 06, 2005 7:21 pm
i have a AGP card...and by 64-bit plunge i mean upgrading my mobo and CPU to 64-bit
PostPosted: Sun Mar 06, 2005 7:28 pm
M-Powered
M-Powered
Yeah, I figured that much, but what's the point if your OS and software is 32bit... It's too early. You should have other reasons to spend the cash on an Athlon64, like gaming performance, not the fact that it's 64bit instead of 32...
PostPosted: Sun Mar 06, 2005 8:30 pm
im not just doing it to say that i have a 64-bit proc. I do game alot and my athlon xp 2100+ just cant cut it for the newer games.
PostPosted: Sun Mar 06, 2005 8:57 pm
what vid card do you have?
PostPosted: Sun Mar 06, 2005 8:59 pm
i have a GeForce FX 5200
PostPosted: Sun Mar 06, 2005 10:05 pm
actually i've changed my mind. I'm going to get the Asus K8N-E mobo with the Athlon 64 3000+. Any thing better for under $400?
PostPosted: Sun Mar 06, 2005 11:13 pm
What does the K8N-E have that justifies spending the $20 more over the regular K8N?
PostPosted: Mon Mar 07, 2005 5:35 am
An "E."
PostPosted: Mon Mar 07, 2005 12:05 pm
more SATA ports, dual raid, firewire....better coolness?
PostPosted: Mon Mar 07, 2005 6:44 pm
get this mobo instead, cdn site also!
PostPosted: Mon Mar 07, 2005 6:51 pm
iwould get that one, but its socket 939...i dont want to have to buy registered RAM
PostPosted: Mon Mar 07, 2005 7:01 pm
you only need registered ram for s940. not s939. if you want proof go the site i linked in previous post and go to specs and you will see it says 184 pinn un-buffered ram
PostPosted: Mon Mar 07, 2005 7:13 pm
You do not need registered ram for 754 or 939.
If you do go to 939 get a kt880 or an nforce 3 for agp.
