It is currently Sun Mar 29, 2015 11:11 pm
 Post subject: New Build Plan..is it Good?
PostPosted: Sat Jul 27, 2013 10:59 pm
CAS: Raidmax Viper Mid-Tower Gaming Case w/ 1x USB 3.0 Port & Side Window Panel (Black Color)
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
COOLANT: Standard Coolant
CPU: Intel® Core™ i5-4670K 3.40 GHz 6MB Intel Smart Cache LGA1150 (All Venom OC Certified)
CS_FAN: Default case fans
FAN: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
HDD: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive)
IUSB: Built-in USB 2.0 Ports
KEYBOARD1: (Keyboard & Mouse Combo) Razer Cyclosa Gaming Keyboard & Abyssus Gaming Mouse
MEMORY: 8GB (2GBx4) DDR3/1600MHz Dual Channel Memory (Corsair or Major Brand)
MOTHERBOARD: [CrossFireX] MSI Z87-G41 PC Mate Intel Z87 Chipset DDR3 ATX Mainboard w/ Military Class 4, OC Genie II, 7.1 HD Audio, GbLAN, HDMI, 2 Gen3 PCIe x16, 2x PCI-e & 2 PCI (Pro OC Certified)
NETWORK: Intel Pro Gigabit 10/100/1000 Network Card
OS: Microsoft® Windows 7 Home Premium (64-bit Edition)
POWERSUPPLY: 350 Watts - Antec Basiq BP350 Power Supply
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
TEMP: Aerocool Touch 1000 5.25" Touch Screen Fan Control
VIDEO: NVIDIA GeForce GTX 650 2GB 16X PCIe 3.0 Video Card (Major Brand Powered by NVIDIA)
WNC: PCI Wireless 802.11n 150Mbps Network Interface Card
_PRICE: (+866)
Is this a good build for the price??
 Post subject: Re: New Build Plan..is it Good?
PostPosted: Sun Jul 28, 2013 12:36 am
If this is a prebuilt system, then no. The money was poorly spent. If not, then things I'd change are:
  • Better video card to at least a GTX 760
  • Power supply to at least 600W
  • No liquid cooling, a Cooler Master Hyper 212 will do
  • No front panel fan controller.
  • No network card (motherboard already has an Ethernet port)
