It is currently Wed May 22, 2013 11:55 am
 Post subject: Asus P5AD2 and memory
PostPosted: Thu Mar 03, 2005 6:00 pm
I am building a new PC and have choosen this mobo which will use a P4 660 CPU. my question is that I want to be able to upgrade to 4GB of DDR 2 memory in the long run so I need to start off with some memory until I can afford to get to my goal. here is my question. can I install 1 - 1GB stick of memory leaving the other three slots open for slow upgrades over the next 6-12 months or do I have to install the sticks in pairs? I really do not want to put in 2 -512GB sticks and have to replace them down the line.
PostPosted: Fri Mar 04, 2005 8:51 pm
Celeron
Celeron
You really need all of that RAM?
PostPosted: Sat Mar 05, 2005 7:04 am
Not yet but I like the ability to upgrade to it if I do find the need for it. I will be getting into 3-D designing of golf courses in the future and I am currently doing video editing. I really do not like to waste good money on 512mb sticks now if I do not have to. I know that 2gb would do for probably the next year but do not want to be hamstrung at just that amount.
PostPosted: Sat Mar 05, 2005 7:24 am
the benefit of getting two sticks is to run in dual-channel mode. if you have the money, probably you can get 2gigs right now. check out www.newegg.com for the good deals.
PostPosted: Sat Mar 05, 2005 8:50 am
Celeron
Celeron
In that case, screw Dual-Channel - for now. Your system would still operate fine without it.
PostPosted: Sat Mar 05, 2005 4:10 pm
Thats what I was thinking and hopeing. I would rather put the extra money for the cost of a second GB stick into a video card or large sata hard drive to start off with. I could deal with single channel for about 6 months while I get everything set up and running.
Thanks for the info
PostPosted: Sat Mar 05, 2005 4:56 pm
Yeah you should be fine running 1GB sticks of something like Corsair Value RAM or another cheaper brand like Geil. You would have no problem upgrading in the future.
