It is currently Mon Mar 30, 2015 6:04 pm
 Post subject: Linux And Windows
PostPosted: Fri Mar 04, 2005 11:57 pm
I just purchased a new hard drive and instead of getting rid of the older 20 gig hard drive I would like to keep it in and run linux of the old and windows Xp pro off the new. How would you go about doing this?
Would I need to change the boot order everytime I were to boot up and want to use the other OS instead?
PostPosted: Sat Mar 05, 2005 4:40 am
It would be easier if you set up the new disk as master, and make the old the slave. Then install windows XP on the new disk.
Here is a howto on installing linux so it doesn't clobber your windows boot-loader and how to modify it make the linux boot partition accessible.
http://www.geocities.com/epark/linux/gr ... HOWTO.html
