It is currently Sat Jan 31, 2015 2:43 am
Post new topic Reply to topic  [ 19 posts ]
 Post subject: amd heatsinks
PostPosted: Thu Mar 03, 2005 9:42 pm
What the best amd 64 heatsink, i am buying a 3500+ so i want to protect my sweet cpu.
PostPosted: Thu Mar 03, 2005 9:45 pm
Contributing Writer
Contributing Writer
Plan on overclocking? If not, use the stock heatsink/fan that comes with the retail version and stay protected with a 3 yr warranty.
PostPosted: Thu Mar 03, 2005 10:03 pm
Truth.
PostPosted: Thu Mar 03, 2005 10:35 pm
I will be oc to 2.5 if possible. planing on getting a falal1ty AN8 motherboard
PostPosted: Thu Mar 03, 2005 10:50 pm
thermalright xp-90 or xp-120 for air cooling(read thermalright compatability listing on the 120 before venturing forth). If you want best practical cooling, go water.
PostPosted: Fri Mar 04, 2005 8:05 pm
Celeron
Celeron
I bet stock could handle that easily.
If you don't believe me, try stock first then go improve your HSF.
PostPosted: Fri Mar 04, 2005 8:54 pm
im pretty sure that the fatal1ty will not be able to take an xp-120, so it looks like hes stuck with the xp-90, still an awesome heatsink though.
PostPosted: Sat Mar 05, 2005 7:22 am
thermalright would be a good choice. i have the thermalright slk-800 and its cooling my athlon xp 2500+ pretty well.
PostPosted: Sun Mar 06, 2005 10:23 am
I have a 3500+ Winchester on an MSI Neo4 Platinum board. I'm using the stock cooler at 2.4 gigs. [I haven't tried any higher] My current CPU temp is 29c at a room temp of 72f with a well cooled case. The highest I've seen just after coming out of a hour w/Pacific Fighters is 37c.
PostPosted: Sun Mar 06, 2005 12:14 pm
Zalman also makes a good HS.
I think the retailed ones are okay, but a little noisier than it should be.
PostPosted: Sun Mar 06, 2005 12:42 pm
well, from reviews im here to recommend the epox nforce4 ultra board. it should fit the xp-120 plus it ocs like a dream from the reviewers say so. im going with it at this point.
PostPosted: Mon Mar 07, 2005 7:12 am
wait till the thermaltake big typhoom comes on shelves, it has like 8 heatpipes or something.
PostPosted: Mon Mar 07, 2005 8:54 am
heatpipes do not guarentee a good heatsink. in fact that is a poorly designed heatsink, there is nothing connecting the bast to the fins except for the heatpipes, and that will allow the thermalright xp-120 to outperform it, because heat can transfer through the actual connection too. this was shown in a review of thermalright's SI-97 socket a heatsink that could have performed better had the fins been connected to the base.
PostPosted: Mon Mar 07, 2005 9:29 am
Are you serious? They void the warranty if you change the heatsink? wow...
I did know that if you dotn OC there is no point since the heatsink that comes with teh cpu is guaranteed to work.
PostPosted: Mon Mar 07, 2005 9:41 am
Contributing Writer
Contributing Writer
Technically, yes it does. Big whoop IMO though. The bigger picture is it's a waste of funds to buy a third party cooler for the sole purpose of protecting a CPU at stock speeds.
PostPosted: Mon Mar 07, 2005 12:51 pm
exactly. im only going with something other than stock because i plan on ocing.
PostPosted: Mon Mar 07, 2005 11:06 pm
actually other than overclocking, i can think of another reason from experience. I got a friend who has an xpc - it's as full as it can get. But the serious air flow problem that occurs because of it was reason enough to try a better heatsink. (he locked up with stock)
If i want a peltier to turn on with the machine, what's the best way to do so?
PostPosted: Tue Mar 08, 2005 7:06 am
Contributing Writer
Contributing Writer
Most certainly correct, and there's actually a few reasons besides overclocking (such as reduction of noise, maximum thermal performance, aesthetics, etc). My only point, however, is that getting a third party cooler solely to protect a CPU is a waste of funds, which is what the original poster indicated as his reason. Without a need for a non-retail bundled cooler, it's just money thrown away.
In your example above, a third party cooler was needed to address an airflow and ensuing heat problem that resulted from cluttered/full innards. This would be yet another reason to tack on to the above.
PostPosted: Tue Mar 08, 2005 8:59 am
has anyone here used the thermalright xp-90 heatsnk? im thinking about this sink if i go with the MSI nf4 ultra board.
