It is currently Tue May 05, 2015 4:30 pm
 Post subject: amd 64
PostPosted: Thu Mar 03, 2005 9:24 pm
Can anyone tell me want the diffence is between 3500+newcastle and winchester.
Thanks for your time
PostPosted: Thu Mar 03, 2005 9:50 pm
Contributing Writer
Contributing Writer
Dize size of their respective cores. Newcastle = 130nm (.13micron), Winchester = 90nm (.09micron).
Winchesters consume less power, run cooler, and as a result overclock slightly better. From a performance standpoint, they're identical.
Also, depending on your motherboard you may need to update your BIOS before attempting to install a Winchester. This information should be easily found on your manufacture's website.
PostPosted: Thu Mar 03, 2005 10:39 pm
Thanks that will be helpful
