It is currently Tue Jan 27, 2015 4:30 pm
Post new topic Reply to topic  [ 123 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Mon Mar 21, 2005 9:41 pm
depends on the card. for ATI cards I really like ATITOOL. for NVidia cards i like Cool Bits.....good stuff there.
PostPosted: Tue Mar 22, 2005 5:35 pm
How do you remove the front part of the case on the Coolermaster Centurion 5?
PostPosted: Tue Mar 22, 2005 6:25 pm
O.K., I got everything in I haven't started it yet, but I still have a few questions. When I was trying to put that very large ATI Radeon X850XT in I opened too many PCI slots and I can't get them back on, there are about four slots open, will this affect my airflow? Also, I scraped myself a couple of times and bled a little on the motherboard will this mess it up? I'm excited about to start it up, just have to bring the monitor in. :)
PostPosted: Tue Mar 22, 2005 7:31 pm
Well, I plugged everything in the monitor worked, but the fans in the case were going on and off. Nothing showed on the monitor. I'm not sure what's wrong, but I'll keep checking the cables, much help would be appreciated. Thanks.
PostPosted: Wed Mar 23, 2005 2:36 pm
O.K., I think I got the computer itself working because when I press the power switch all the fans turn on and I'm pretty sure the really loud fan is the ATI Radeon X850XT. The only problem I have is that nothing is coming up on the monitor, I have it connected to the graphics card and everything, but it just stays in the "off" mode after I turn everything on, "off" mode is like hibernate or a screensaver, but nothing comes up. I'm nt sure what is worng, any suggestions? The problem witht urning it on was that i didn't ahve the power switch connected to the right place I'm pretty sure.
PostPosted: Wed Mar 23, 2005 3:15 pm
been there done that :)
hmm - did you plug the monitor into the right output? Not sure if it displays on both at start.
PostPosted: Wed Mar 23, 2005 3:25 pm
Lol. Well, yeah I'm pretty sure that the monitor is plugged into the right slot I plugged it into the blue slot directly and the other slot with an adapter or something on it.
PostPosted: Wed Mar 23, 2005 3:39 pm
did you plug the molex line to the card? if so, was a a seperate line just for the card? (not sure if it applies to this card actually)
PostPosted: Wed Mar 23, 2005 3:47 pm
There was a line that came witht the card for PCI Express, but there is also a line that was included with the PSU that was PCI express should I use the line that came with the PSU or the card. But I'm pretty sure it's recieving power because the fan turns on, but I'll try the line that came with the PSU.
PostPosted: Wed Mar 23, 2005 4:02 pm
It seems that the signal cable in the graphics card slot is connected properly to the monitor because when I disconnect it the monitor says "signal cable disconnected" or something along the lines of that. Maybe one of the other parts isn't functioning right.
PostPosted: Wed Mar 23, 2005 4:37 pm
if you mean there was a molex to pci-e adapter vs a dedicated pci-e line from the psu, use the pci-e line from the psu.
you're not hearing any beeps or anything are you?
how much what's your psu's power rating?
PostPosted: Wed Mar 23, 2005 5:05 pm
Well, I'll try using the dedicated PCI-E line from the PSU, the line that came with the card was a split that also connected to the hard drive. I'm not hearing anything, but fans, however, if I plugged a kepyboard into the USB portwould it detect it immediately because I turned the computer on and then pressed the NUM lock key and nothing happened on the keyboard indicator. My PSU rating is 520 w.
OCZ PowerStream
PostPosted: Wed Mar 23, 2005 5:15 pm
I gave the Hard Drive and the graphics card their own separate lines and it doesn't seem to have made a difference. The Power LED comes on when I start the computer, but the Hard Drive LED doesn't is their a reason for this? I have an SATA hard drive and there is a big power connector specifically for SATA I'll connect that, but I'm not sure it will make a difference.
Maxtor HD
PostPosted: Wed Mar 23, 2005 5:48 pm
dmanit I keep hitting this button on the inside of the case on the motherboard that resets and puts poer into the motherboard or somin and then the fans will go on for a second and then turn off and it will keep doing this i don't kno why this keeps happening, but this is like the 3rd time and its pissing me off, i dont kno how i fixed it last time. how do i get this undone or w/e?
PostPosted: Wed Mar 23, 2005 6:50 pm
I had the same problem with mine. Are you using Dual channel memory? If so make sure they are in the right slots 1 and 3 (thats how it was on mine). Also tidy up the cords and check the connections. And make sure everythings right side up. I put my dvd buner in upside down first time i did it. And make sure if you use the molex adapters that you plug both of them in.
PostPosted: Wed Mar 23, 2005 7:04 pm
What problem are you reffering to? The fans and lights going on and off or the monitor not connecting with the graphics card right? Right now I'm trying to figure out what went wrong with the power/reset buttons? I ahve my memory in dual-channel and tidying up my cords is almost impossible, it's a mess. I shoved them all in the empty corner where my CD drive is. What do you mean by your comment on the molex adapters?
PostPosted: Thu Mar 24, 2005 1:02 pm
Sorry, but by the way I forgot to say that there is no audio whatsoever installed currently. The onboard audio would not fit because of a fan, and I have not yet gone out to get an Audigy card. How do I get my signature to show right below my messages? It includes all of my computer information.
PostPosted: Thu Mar 24, 2005 4:05 pm
Well, this motherboard is really starting to get on ym nerves so I think I'm going to return it and find a new one. Any suggestions?
PostPosted: Thu Mar 24, 2005 6:01 pm
Celeron
Celeron
MSI K8N Neo4 Ultra
PostPosted: Thu Mar 24, 2005 6:15 pm
How about this motherboard? I'm concerned that the onboard audio or other port will interfere with the fan in the rear of my case as the audio with my other motherboard did.
ASUS A8N SLI-Deluxe Motherboard
