Hi, I'd just like to say thanks in advance to anyone that replies to this, because I'm really desperate.
Okay, first of all, this is about the computer I'm building/built. Yes, it is my first home-brew computer (I'm 16), but I don't really think of myself as a n00b- I've done lots of stuff with computer hardware before, and I'm actually the current tech guy for this local charity organization where peopel bring in old shit (and yes, I mean shit, PII's are a regular) computers, and I have to fix them up/mix and match parts together to put them into working conditions to give out to local needy families.
Anywho, I finally got aroudn to getting together all teh parts for building MY computer:
MB: Intel D875PBZ
CPU: Presc(h)ott 3.2 GHZ 478 pin
Heatsink/CPU fan: Thermaltake Spark 7+
Video card: ATI Radeon X800 Pro
Ram: 512 mg Infineon (from a friend, to be upgraded to 1 gig matched kingston/crucial when I get some money. which should I get?!?! kingston or crucial?)
Soundcard: when I get some money
Monitor: 19 CRT from local charity I work at! (who says charity work doesn't pay)
Harddrives: 2 80 gig SATA Seagates barracudas to be set up in Raid 0
Case: Antec Solution series SLK2650-BQE w/ 350 watt smartpower supply
(and 1 floppy drive + 1 CD drive)
anywho, I got all teh parts assembled, plugged everything in, etc etc etc (I'm fairly confident I did everything right...)
I plugged in the monitor and PSU, yada yada yada, and turned on the switch on the power supply, which cased a little green light on the MO to light up and stay lit, if thats of any importance...then the moment of truth-
I popped the power button on the front of the computer, and all the fans and everything started whirring for about 1-2 seconds, and then died off. I tried againa dn again, and everytime they would start up and then die down right away. So then I tried the standard approach- I stripped it down to just the CPU, RAM, and MO. same thing. Then I even tried taking out the ram. same thing. I plugged the video card back in, no good. I even tried this old TNT2 video card I had kcikin around, and no go again!. After toying around for a really long time, plugging stuff in, unpluggign stuff, turning on and off, all of a sudden it started up! The fans started and CONTINUED running happily. And BTW I'm about 99% sure that when it started up, it was in a configuration I had already tried...but whatever. Anyways, after it started up, nothing appeared ont eh monitor still! It jsut sat there glaring at me, and I know it isn't the monitor, because after that I tried hooking up all sorts of different monitors, and none of them wokred. I even tried the monitor that I'm looking at RIGHT NOW as I type this (on the family computer). Anyways, I turned off the PSU, and plugged some more stuff back into the power supply...and got the orginal deal. started up, then went dead again. So of course I disconnected all that stuff again, and rebooted...but still the 1-2 secs then nothing. Ugh. After tyoing around for about 1/2 an hour, all of a sudden it started up agian! fans whirring and everything! This process has repeated itself at LEAST 5 times now, not working, then working, then not working, then working. I think It has SOMETHING to do with me turning on and off the power supply, because if I just turn off the computer with the power button on the front, if it previosly didnt work, no matter what I do, it still wont work, whereas if it previosly WAS working, and I dont kill the manual switch ont eh power supply, and use the front power button, it'll continue running after I reboot, even witht eh beastly video card and everythign else hooke dup, soi it DEFF isn't just a lakc of power. Anyways, I've tried everything, poppong out the CMOS battery , changing the BIOS jumper, all that ####, and I STILL cant get anything to come up on screen! and soemtimes the computer wills till go back to the original state if I kill PSU power, but soemtimes it will stay happy! I have NO CLUE whats causing that.
ACK! HELP ME GET A BOOTUP SCREEN!
Oh, and on top of ALL that (ugh, you're really going to kill me), at one point When I had power up and running and everything to the comp, I decided I didn't feel liek powering down (even with the fornt panel power button) before plugging the molex power into my CD drive again...so I bring the connector over towards it, and when they're about to touch, or maybe just had, theres a big ZAP, and a mini blue lighting bolt...uh-oh. The whoel computer dies down, and I kill PSU power....wait a few minutes, and boot back up...case #1, 1-2 secs fan power, and then dies down. after fiddling around soem more, I actually managed to get the fans to keep going, so it at least APPEARS that all systems are go still, the box will sit there happily running for as long as I want until I shut it down, but still NOTHING ON SCREEN! ON ANY OF THE MONITORS. NO POST, NO BIOS. NOTHING.
P.S.- it just occured to me, after another hour of searching online for a solution prior to posting (yuk yuk) this message and bugging you all to unplus the CMOS battery and leave it that way for like 20 mins. previosly I always just popped it out, waited like 5 secs, and put it back in...I'll come back and reply after I see how that goes.
P.P.S.- no beeps ever.
Now to just hit the big POST button...ah the irony...
