It is currently Fri Mar 27, 2015 4:21 am
 Post subject: do i have a kick ass 3500+
PostPosted: Tue Mar 01, 2005 9:29 pm
i have been looking at peoples idle and load temps in the 3500+ OC thread and found after applying Arctic silver 5 i get an idle temp of between 10C and 25C and a load temp of between 38C and 45C. could my MSI core cell app be reporting wrong?
I use stock cooling but do have a xaserV case with awsome air flow.
these temps are with the FSB at 225 Mhz for a total speed of 2.5 Ghz.
PostPosted: Tue Mar 01, 2005 9:35 pm
just restarted the bios says its 30C
PostPosted: Wed Mar 02, 2005 8:59 pm
What voltage are those temps at? Is your chip a Newcastle or a Winchester? I have a 3500 Newcastle at 260X10@ 1.6V that runs at 37 idle and 49 load.
oh, and I'm running a thermalright XP-90
PostPosted: Wed Mar 02, 2005 9:15 pm
wow i can't belive i forgot to say this its a newcastle. running at stock everything cept FSB 225 with an 11x multiplier. really crappy ram too just corsiar value select DDR400 512 x2 in a MSI NEO2-F.
PostPosted: Wed Mar 02, 2005 10:14 pm
o crap thats good, basicly since i plan on investing in a 3500+ winchester and ocing 400 mhz (fx55 speed) with a thermalright xp 90
PostPosted: Thu Mar 03, 2005 8:07 pm
that s/b a very nice combo, the XP-90 is a phat heatsink. You will have some low temps with this combo. Which mobo do you have?
PostPosted: Thu Mar 03, 2005 8:49 pm
Have you guys seen the new SB series?
Its pretty much the XP series but copper instead of alumn.
Looks very promising.
PostPosted: Sun Mar 06, 2005 4:06 am
no...no I didn't! Where can I see one? Sounds completely awesome indeed. That thing must be heavy. I wonder what kind of backing plate they'll make us use??
PostPosted: Sun Mar 06, 2005 11:28 am
i use a MSI NEO2-f, it has a K8T800
 Post subject: Re: do i have a kick ass 3500+
PostPosted: Sun Mar 06, 2005 11:38 am
Celeron
Celeron
The program could be reporting incorrect temperatures. Or it could be because you have the Cool-n'-Quiet feature on which explains the awkwardly low temperatures, but normal load temps.
PostPosted: Sun Mar 06, 2005 3:05 pm
i disabled cool and quiet because it runs cooler with out it. all it does is decreases fan speed when your CPU is cool
