Hairpuller wrote:
As long as you don't mind some noise. That's a lot of fans.
Its a bit loud on full speed. Just add in a nexus controler I like the nexus-305-bk as it fits in a 3.5 slot. The factory setup has 3 fans on 4 pin connectors & the rear fan is a 3 pin. All you need to do is run out to radio shack & buy a couple of the male to male 3 pin extentions & some shrink wrap. clip the old pins & then you can clip the male to male extender where ever you want to add length to you fan connections. The back fan already has a 3 pin but it is a bit on the short side for my mobo (I got an asus p4p800 se) so I moved this fan to the top fan slot & rewired the rest. I am running a P4 2.8C @ 3360.9MHz FSB Frequency @ 240.1 MHz(960.3 MH Bus Speed) 1024 MBytes G.Skill DDR-SDRAM PC4400 @ 1:1 FSB ratio with 2.5-3-3-6 timing 1 IDE Samsung 80HDD & 2 SATA WD 120HDD in raid 0 & a Leadtek 6800 GT Oced to Ultra settings. My idle temps run 28C cpu & 30C Case 44C under full load with 40C Case temp. Which is awsome for a Oced setup. I had considered modding my case but with the temps I get I decided to leave it alone. My benchmarks are also right up there with todays power rigs for about half the cost.
