It is currently Thu Jun 20, 2013 12:46 am
 Post subject: Question on Cathode inverter
PostPosted: Tue Mar 01, 2005 4:32 am
Is there an inverter with multiple plugs for cold cathode lights out there. I'm talking more than two plugs in it. I want to consolidate my lights in one specific place. TIA.
PostPosted: Tue Mar 01, 2005 5:06 am
i would not use a cathode, there have been many horror stories on the internet of people using them and having the inverter literally explode ruining their systems.
PostPosted: Tue Mar 01, 2005 7:34 am
What would you use them ? Are you saying no lights at all ? Just curious.
PostPosted: Tue Mar 01, 2005 7:39 am
two cathodes is not enough?
PostPosted: Tue Mar 01, 2005 8:33 am
I have a cathode lights on one fan close to the bottom, another one running across the bottom of the case but the case is not lighted toward the top. I have an NVIDIA 6800 GT card which covers the light due to it's size and i was hoping to add another one closer to the top. Thinking about it now, it could be too much of a good thing. I was curious as to a device that you could plug all your lights in.
PostPosted: Tue Mar 01, 2005 8:54 am
i would use led's. you can buy led "spotlights" and led tube lights that work just like cathodes but dont use an inverter.
PostPosted: Tue Mar 01, 2005 9:06 am
From what I hear, UV LEDs just aren't the same.
PostPosted: Tue Mar 01, 2005 12:13 pm
I have seen EL lights but can't recall LED tube lights. Can you point me to a site so i can read more about it ? Thanks.
