It is currently Mon Jan 26, 2015 2:37 pm
 Post subject: Budget Build
PostPosted: Sun Feb 27, 2005 2:24 pm
Looking for some input on my budget build. I am basically doing an 85% upgrade to my current system. I'll be using my current alumninum case, 400w Enermax PSU and Audigy Soundcard along with my floppy and DVD-Rom. Here's the rundown:
DFI LANPARTY UT nF4 Ultra-D - $144
AMD Athlon 64 3200+ Winchester - $180
Leadtek nVIDIA GeForce 6600GT - $152
Mushkin Dual Pack 184-Pin 1GB(512MBx2) DDR PC-3200 - $123
Seagate 200GB 7200RPM Barracuda 7200.7 SATA Hard Drive - $79
NEC 16X Double Layer DVD±RW Drive - 60
Total=$738
Any opinions would be appreciated, looking to order this week.
PostPosted: Sun Feb 27, 2005 2:26 pm
I would get some ram with better timings if you could. Especially if you look to overclock.
 Post subject: Ram opinions
PostPosted: Sun Feb 27, 2005 7:12 pm
Any thoughts on RAM? I most likely not be OCing or will only OC a little bit. I am just looking to save some loot but would like to get good performance as well.
PostPosted: Sun Feb 27, 2005 8:49 pm
Contributing Writer
Contributing Writer
I'm assuming you're talking about this Mushkin HERE? If so, that's actually very decent for ValueRAM (2.5-3-3). That also happens to be the cheapest 1gb PC3200 kit Newegg is offering. I'd stick with what you have spec'd.
PostPosted: Sun Feb 27, 2005 9:35 pm
every thing looks good to go!
PostPosted: Mon Feb 28, 2005 8:34 am
definitely pretty good. nice system specs. build it and post some benchies.
Users browsing this forum: amerifax and 9 guests
