It is currently Tue Jan 27, 2015 11:58 pm
 Post subject: Building a new PC, need help w/ compatibility please
PostPosted: Sat Feb 26, 2005 7:45 pm
Hey all, I'm trying to build my first PC and I need a little help making sure everything is compatible before I buy it. I'm gonna post the components below, if anyone sees any compatibility issuses, please let me know before I buy the parts.
AMD Athlon 64 3000+ skt. 939
ASUS A8V-Deluxe Via K8T800 Pro
Corsair CMX512-3200C2 512MB DDR400 PC3200 XMS
Thermaltake XaserIII Lanfire
Enermax EG425P-SFMA24P 420W Power Supply
ATI Radeon 9200 (Recycled)
Sound Blater Audigy 2 ZS (Recycled)
Maxtor 6Y080P0 80GB HDD 7200rpm (Recycled)
D-Link DWL-520 Wireless PCI Adapter (WLAN) (Recycled)
LG HL-DT-ST CD-RW GCE-8320B (Recycled)
LG DVD-ROM DRD8160B (Recycled)
One thing I'm worried about is that I may not be able to run my Radeon 9200 at the full AGP 8X, but im not sure about that. Thanks for all your help guys,
Inkorporeal
PostPosted: Sun Feb 27, 2005 5:54 am
on behalf of all posters here I have to thank you for posting links.
Looks like an awesome system, with the exception of your 9200, which will work just fine in 8x mode - weather or not it will utilitize full potential can be easily argued.
It should be your first upgrade consideration, may I suggest:
EVGA's 6600gt <$200 @ zzf link>
Asus' V9999GT/TD GeForce 6800 GT AGP 8X 128MB <$315 @ zzf> - an interesting mid-range hybrid
the BFG GEFORCE 6800 GT OC 256MB <$400 @ buyxg> a hands-down great performer (I have one)
Also, as a personal preference I would probably choose Nforce 3 over K8T, but from what I have read about the K8T Pro they had fixed a lot of the original K8T's flaws so perhaps is not such a bad choice.
PostPosted: Sun Feb 27, 2005 9:34 am
if you are gonna play FPS games then i recommend getting at least 6600GT card but if you are not, then its ok. looks good, happy building.
PostPosted: Sun Feb 27, 2005 5:55 pm
Heh, the links took a long time, but I find people are more likely to help you out if your considerate of them. The vid card will be the first upgrade, but atm, I dont have the money for it; alot of the hardware I have to recylcle from this comp. but it will be my first order of business after I finish buying and building. Thanks for all the help guys,
Inkorporeal
P.s. I do play some FPS', but for now im just gonna run them at the lowest setting
