It is currently Sun May 26, 2013 1:03 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Help Yourself Buy/Build/Quote.
PostPosted: Thu Feb 24, 2005 5:57 pm
Chief Surgeon
Chief Surgeon
This is a little guide as to making our assistance in this folder easy for you and us. :)
1. Don't be vague. "I want a machine I can play games with" is vague. Rather, "I need to build a gaming rig for playing Half Life 2 in all it's glory" is much better. The more details you provide, the better and more accurate our listings will be for you.
2. List anything you'll recycle into this project. Monitors, keyboards, mice, peripherials, software and operating systems are included, if you recycle. Remember, if you plan on donating/giving/selling a current system, you must adhere to any EULA for software going to that machine.
3. Give us a budget, preferrably a target. $850 to $1000 rather than $925 give the participating members a little leeway to utilize their skills and favorite items.
4. Please don't start any AMD/Intel or nVidia/ATI Fanboy wars here. 'nuff said. All of the above products work well for some, not well for others.
5. If you have a preferred method of shopping, please include that. Some people favor newegg, some zipzoomfly, et. al.
6. (Thanks, DreadedOne509) Adding links can add a great deal of useful information to your post. However, adding several links that are not descriptive can turn some people away from even looking at them due to either time constraints, or those that have low bandwidth connections.
This is an example of how not to do a link in your post:
http://www.newegg.com/Product/Product.a ... 6800999137
This tells the reader nothing about what you are linking to except that it is something from NewEgg.com. Here is that same link done just right:
NewEgg Glossy Logo Sticker $5.00
Here is how it is done:
[url=http://www.newegg.com/Product/Product.asp?Item=N82E16800999137]NewEgg Glossy Logo Sticker $5.00[/url]
The url=web address is enclosed in brackets, then description, then closing brackets /url.
It is super-easy to do, takes about 1/10th of a second longer than just adding a link the other way, and conveys so much more usable information.
*** NEW *** 7. (Thanks, Longhorn19) If a video card/video cards are in the purchase - and you are planning to keep your current monitor(s), please list that Make/Model monitor(s), and it's known resolution(s). This way, we can help you get the best bang for buck without draining your 401(k). ;)
Thank you all for your participation.
SuperChip64
MaximumPC Forum Moderator
PostPosted: Fri Feb 25, 2005 9:54 pm
By "recycle" you meant reuse, correct?
Recycling would imply you're donating the part to a recycler where it will be broken down and the indivicual parts will be recycled into lesser forms to be later reused as something similar... or something completely different.
PostPosted: Fri Feb 25, 2005 10:00 pm
Chief Surgeon
Chief Surgeon
That's correct.
As an Example, You just bought an Audigy2ZS Platinum. You want to recycle that into your new build.
That's my definition of recycling.
Sorry for any confusion. :)
SC64
PostPosted: Fri Feb 25, 2005 10:04 pm
Well, it'd seem kinda silly when used in that slogan from the 90's-- reduce, reuse, recycle :P
