It is currently Sun Apr 26, 2015 10:30 am
 Post subject: fx-53 oc'ed to fx-55 specs
PostPosted: Thu Feb 24, 2005 5:08 pm
Can someone please tell me how to overclock the 53 to the 55. I know I have to flip the multiplier to 13, But is there anything else I have to do to make everything stable and cool. And is the stock cpu fan gonna cut it?
PostPosted: Fri Feb 25, 2005 7:08 pm
you dont need to changed the multiplier, and you wont be able to anyway. It only takes 200MHz, 90% likely that you'll be able to reach that. Just go into the bios and increase your FSB from 200 to 217 (math?), from 2400MHz to 2600MHz. probably raise your voltage a SINGLE notch. if you raise any more than that, you need to get a new cooler.
I would encourage you to try to OC farther than that. RTM. look on some other guideline posts, or google "overclocking guide", etc. happy OCing
PostPosted: Fri Feb 25, 2005 8:18 pm
Thanks!!!
PostPosted: Tue Mar 01, 2005 8:35 pm
why wont he be able to change the multiplier? The FX is unlocked.
PostPosted: Tue Mar 01, 2005 8:57 pm
Team Member Top 100
Team Member Top 100
Yeah, the FX series is unlocked, and multiplier OCing is much better on the Athlon 64s than OCing by the FSB.
