It is currently Wed May 06, 2015 4:34 am
 Post subject: Help me upgrade!!! :)
PostPosted: Wed Feb 23, 2005 10:43 am
Currently what I have:
Motherboard: ECS K7SEM with On-board processor Duron 1300+
Memory: PC133(WAY OLD!)
Video: Geforce FX 5200 Ultra(Pretty old too, only has 4 pipelines)
Case: So old I dont even know who made it.
Just looking for upgrades so I can run today's games fairly good(Graphics and all)
Thanks for any help in advance! :D
PostPosted: Wed Feb 23, 2005 11:16 am
How much money do you have to spend?
PostPosted: Wed Feb 23, 2005 11:20 am
800$
PostPosted: Wed Feb 23, 2005 12:57 pm
Athlon 64 3000($155)
Asus A8V-E Deluxe($170)
1 GB Corsair Value Select($130)
eVGA GeForce 6600 GT PCIE($192)
Seagate Barracuda 160 GB HD($109)
CM Centurion 5($80)
Antec NeoPower PSU($125)
That's all about $960, a tad over budget but I beleive it should be quite upgradable. Also the Centurion 5 comes with a 350w PSU but I'm not sure if it has a 24pin connector for the mobo or a 6 pin connector for the PCIE video card, and adapters are annoying to find if you ask me. As for a the CD Drive, you can probably use your current.
BTW, all the prices are from www.newegg.com you should also compare with www.zipzoomfly.com
Also if you plan to do any overclocking I'd go for an NF4 Chipset mobo such as the DFI Lanpary UT NF4 Ultra D for $144 on Newegg.
Enjoy your build!
