It is currently Wed May 22, 2013 1:44 am
 Post subject: What is the best home server (AMD) Motherboard?
PostPosted: Sun Feb 20, 2005 8:31 pm
I want to build a home server,it's gonna run LIBRAnet 3 Linux, which is in beta testing now.
I'd like to know if I should go with an Opteron (Single Chip) or an Athlon 64.
As I understand it, the Athlon 64 allows for DDR2, non-registered memory.
The Opteron requires non-DDR/Registered memory.
If that info. is correct, then the opteron >May< Be the slower system.
Then again, I could get a dual-chip Opteron, run it single-chip, and get the other CPU later.
I'm beside myself on this, nobody I can find compares the Athlon64 Motherboards to the Opteron's.
Thanks.
 Post subject: Re: What is the best home server (AMD) Motherboard?
PostPosted: Sun Feb 20, 2005 8:40 pm
Celeron
Celeron
To clear things up, the A64/Opteron line both use DDR. The rest of your understanding is correct. :)
I have no experience with servers and whatnot, so I'll leave that up to someone else. :P
