It is currently Sat May 18, 2013 12:59 pm
 Post subject: which hard drive to go with
PostPosted: Fri Feb 18, 2005 10:43 pm
Which hard drive should I get?
MAXTOR 200GB SERIAL ATA/150 7200RPM, or Western Digital 200GB SATA 7200RPM 8MB CACHE.
PostPosted: Fri Feb 18, 2005 10:53 pm
Which model Maxtor drive is that? The Maxtor Diamondmax 10 with a 16mb cache is a solid choice. I have the 300GB model as my storage drive and a WD Raptor 74GB for my OS.
PostPosted: Sat Feb 19, 2005 12:59 am
Anyone ever check out the new ibm deskstars? Yes its true in the past they had issues but i can attest that not only are they cheap they support 42 bit LBA that when turned on Gave me a 11mb sec boost iwhen i Benchmarked using Sandra. It even outpreformed my ata 133 mode 6 maxtor - the ibm is only mode 5. Unless im using SATA i build my rigs with em, ive seen them on tigerdirect for like 50 bucks for a 80 gig and mached to a ATA RAID controler give stupid fast results. 250 for raid 1-0.. Cant beat it with a stick
 Post subject: Re: which hard drive to go with
PostPosted: Sat Feb 19, 2005 3:23 am
Folding Momerator
Folding Momerator
What are you using it for and how are you setting it up?
PostPosted: Sat Feb 19, 2005 6:40 am
I think if you are just looking from brand to brand a lot of times it's a matter of preference. A lot of people won't buy one brand because they have had bad experiences in the past, while others have had the complete oppisite. I myself usually tend to stick to Western Digital drives, but a lot of times I think thats due to prices, and the fact that Maxtor really pissed me off. Their phone support was terrible at the time.
PostPosted: Sat Feb 19, 2005 7:12 am
Out of your two choices, I would get the Maxtor. Now as for speed, you can't beat a Western Digital Raptor, of course with the drives you pointed out ranging in the 200gb, it's obvious your more or less wanting storage over speed.
Out of MY choice, I would get neither. I have always used Seagate drives with minimal problems, so that's my choice.
Let's just do a quick compare though, so you can decide easier.
____________________________________________________
Maxtor-Seek time (9.3ms) NCQ-(y) Buffer-(8mb) Warranty (3years)
WD-seek time (8.9ms) NCQ-(n) Buffer-(8mb) Warranty(1year)
Seagate-seek time (8.0ms) NCQ-(y) Buffer-(8mb) Warranty-(5years)
Scwhing! As you can see, Seagate just pwned these other drives. Be a dear lad, and go grab yourself the 200gb SATA NCQ enabled Seagate ST3200826AS. You'll be glad ya did.
PostPosted: Sun Feb 20, 2005 2:41 pm
I have that particular seagate. It works fine, didn't benchmark it or anything though.
PostPosted: Sun Feb 20, 2005 4:23 pm
I have always been a WD guy nut just this last week I bought my first non WD drive. It is a Seagate 200 gig. I have not yet got the computer totally running. So I can not comment on how the Seagate preforms, but I have never had a spot of trouble with my WD's.
PostPosted: Sun Feb 20, 2005 4:37 pm
Umm if they have the same specs. whatever one is cheaper.
PostPosted: Sun Feb 20, 2005 5:30 pm
Location: Kicking the crap out of the people who lied to me about using Folding@Home and those who declined!!
id say whichever has a better warranty, whichever company u like better, price, and tech support play in there
PostPosted: Sun Feb 20, 2005 7:18 pm
Notched on both sides
I've had 3 in the shop come back bad (ordered 4 per customer request)... I'd say those weren't good odds... Also of note - they don't "appear" to be all from the same batch so that rules a batch issue out...
Tuathal
