It is currently Tue Jan 27, 2015 7:00 am
 Post subject: Overclock?
PostPosted: Sat Feb 19, 2005 2:01 pm
Hi,
I haven't overclocked my computer before other than my vga. Currently i have a 3.4gHZ LGA 775 pentium 4 with a thermalright xp-120. How do I overclock? And how far do i go?
Also...
I have 1024 mbs of Corsair pc3200 value ram (not ddr2), is there anyway i can overclock those?
My mobo: GA-8l-915p DUO -A
PostPosted: Sun Feb 20, 2005 12:19 am
You need to google for a guide to overclocking. You wont be able to overclock much with the ram you have tho you dont have any headroom.
If you want our help you are gonna have to give us more info. We need to know all you system stats that are relavant to speed. Download CPU-Z & run it then go to the last tab (labled about) & click the hmtl report button. Save this & then copy paste it here & we will try to get you started.
 Post subject: Here are the specs.
PostPosted: Mon Feb 21, 2005 9:37 am
CPU-Z Report
CPU-Z version 1.27.
CPU(s)
Number of CPUs 2 (1 Physical)
CPU#1 APIC ID = 0
CPU Name Intel Pentium 4 550
Code Name Prescott
Specification Intel(R) Pentium(R) 4 CPU 3.40GHz
Family / Model / Stepping F 3 4
Extended Family / Model 0 0
Package LGA775
Core Stepping D0
Technology 0.09 µ
Supported Instructions Sets MMX, SSE, SSE2, SSE3
CPU Clock Speed 3416.5 MHz
Clock multiplier x 17.0
Front Side Bus Frequency 201.0 MHz
Bus Speed 803.9 MHz
L1 Data Cache 16 KBytes, 8-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 1024 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3416.5 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
CPU#2 APIC ID = 1
CPU Name Intel Pentium 4 550 (logical unit)
Mainboard and chipset
Motherboard manufacturer Gigabyte Technology Co., Ltd.
Motherboard model 8I915P Duo-A, x.x
BIOS vendor Award Software International, Inc.
BIOS revision F2
BIOS release date 06/09/2004
Chipset Intel i915P/i915G rev. B1
Southbridge Intel 82801FB (ICH6) rev. 3
Sensor chip IT 8712
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 201.0 MHz
FSB:DRAM 1:1
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 2
Module 0 Corsair DDR-SDRAM PC3200 - 512 MBytes
Module 1 Corsair DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
PostPosted: Mon Feb 21, 2005 12:22 pm
Your not going to have a lot of room with that chip. In your bios under advanced settings. there should be a place where you can adjust the FBS you are running at 201.0 MHz this is the only place you need to worry about adjusting for now. Did you go look for a guide to OCin on Google?
You might not be able to OC very much but I think you should be able to handle 220.0 MHz or so.
PostPosted: Mon Feb 21, 2005 2:06 pm
Sorry I really can't find a good article on overclocking, and I've spent a while "Googleing". Can anyone find me a tutorial or article of some sort. Any help will be greatly appreciated.
PostPosted: Mon Feb 21, 2005 3:00 pm
I typed in Overclocking basics & this was the first thing I googled. Overclocking Basics Guide
PostPosted: Mon Feb 21, 2005 3:20 pm
I found this one. It might help.
