havocdragon wrote:
Hey all.
I am currently shopping for ram at newegg right now, and they have on sale some ram made by a company named rosewill, which is 512megs of pc3200 ram for 57$!! The latencies look a bit high, but many people in the reviews seem to have good luck with overclocking them. My other choice was to go with the corsair value select ram (same specs) for 67$ each. Will there be a difference in performance? I dont really plan to overclock either. Last but not least, is rosewill worth going with?
Go with the Corsair Value... its of much higher quality then the price would suggest. From the timings discussed in the NewEgg review it looks like the Corsair would overclock with a bit more stability and success. Personally I have a system with 1g of Corsair Value... 512x2, and I was able to overclock my CPU from 2.2 to 2.5. I would get Corsair, but wouldn't be afraid to go with the Rosewill.
