It is currently Sat Apr 18, 2015 5:25 pm
 Post subject: Ocing problems
PostPosted: Tue Feb 22, 2005 7:06 pm
Whenever I try to oc my 2500+ to 2.2 GHz it sometimes just reboots the system. This can happen when I try to install something or try to run a game. At 2.0 GHz everything works fine. Also when i load 3DMark03 it says that there is a file missing, this only happens when oc'd. Why is this happening?
Specs:
AMD Athlon XP 2500+
Abit NF7-S2G
Sapphire Radeon 9600Pro Atlantis
512MB PC3200 Kingston ValueRam
Seagate 7200.7 80GB SATA
PostPosted: Wed Feb 23, 2005 5:33 am
You prolly have hit your wall, for the moment at least.
Try bumping, ever so slightly though, your core voltage and see if its any more stable.
If that doesnt work then you have hit your wall.
Also, how are your temps?
It could be a heat issue.
PostPosted: Wed Feb 23, 2005 8:37 am
My temps are okay. I have played HL2 for an hour and the my proc is 38C.
PostPosted: Wed Feb 23, 2005 8:38 am
I have raised the Vcore and DRAM voltae and evrything is fine now.
PostPosted: Wed Feb 23, 2005 8:57 pm
Try and see if you can keep the DRAM volt at stock.
If not its not a big deal but it would be better if you could.
PostPosted: Thu Feb 24, 2005 4:17 pm
I only raised the DRAM voltage by 0.5 volts. 2.65 Volts total
