It is currently Sat May 25, 2013 4:20 am
 Post subject: The Case. The Case. The Case?!?!
PostPosted: Fri May 27, 2011 10:13 am
Hey Guys, I appreciate the help that you are going to give me in advance 8)
Around 6-8 months ago i built myself a computer, costing around 1k. Slandered i5, 1TB HD sort of build. At the time, I purchased myself a case that was on sale at Newegg, just wanting to have something to put everything in. Well now I have a lan party coming up, and want to spice up my case a little!
I'm looking for something in the $80-120 range. As an example, recently reviewed in max pc was the Sentey Arvina. I liked the looks of that one, but it seemed the internals didn't quite deliver, and I decided that i wouldn't purchase it.
So, i'm looking for a mid tower case,that is preferably black, with maybe a readout on the front with fan speed etc, nothing too flashy, that can fit two or three hardrives.
Think you have something to help? Thanks!
 Post subject: Re: The Case. The Case. The Case?!?!
PostPosted: Fri May 27, 2011 10:42 pm
Team Member*
Team Member*
If the case is for a LAN party does that mean it will be mobile and needs a handle?
I can't say that I would go for any Sentey products but that's because they haven't wowed me yet with quality of their construction.
Also if you want a case with a LCD fan display you may have to get that separately there are plenty to choose from.
check here: http://www.frozencpu.com/cat/l3/g34/c17 ... d=6r4uTW8L
Here are some case choices:
CM Enforcer
http://www.newegg.com/Product/Product.a ... 6811119240
Bitfenix Survivor
http://www.frozencpu.com/products/12615 ... c7s429b193
NZXT Guardian
http://www.newegg.com/Product/Product.a ... 6811146070
CM 690 II Adv.
http://www.newegg.com/Product/Product.a ... -_-Product
Take a look at the 5.25" fan controllers that are LCD that you may like and can be put into any case it will open up your possibilities.
PostPosted: Sat May 28, 2011 7:18 am
Thanks for your reply, it is much appreciated. As far as it needing a handle, no it doesn't. I was just saying I would like a new one to show off at the LP.
I am somewhat a fan of this one - http://www.newegg.com/Product/Product.a ... 6811146070
But I'm not sure I like the design on the front.
Is their anyway I can narrow down what sort of case I am looking for?
Also, thanks for the advice on the fan controller etc. I will keep that in mind!
Edit: I looked some more, and I like this case http://www.frozencpu.com/products/6257/ ... s429#blank
However, It only has one picture, anybody have some more, or something of that nature? Also, I was looking, and saw that you could purchase a fan control installation, Anybody know what that would look like on this case?
Thanks.
PostPosted: Sat May 28, 2011 1:54 pm
Personally I've been looking at this case for my own build Thermaltake V9 BlacX Edition with Docking Station (NewEgg Exclusive) SECC / Mesh ATX Mid Tower Computer Case Its 89.99 and says it has a mail in rebate.. coupled with one of these Aerocool F6XT 6 Channel Fan Controller / 5.25" Bay / Multi LED Color Display - Black For your front lcd panel 29.95 your looking at just around the top end of the budget you wanted and i think these paired would make a sweet home for a rig.
Good hunting
~Ghost~
PostPosted: Sun May 29, 2011 1:56 am
Wiked_smart wrote:
For $80-$90, there is no better case!
