It is currently Wed May 22, 2013 12:01 am
 Post subject: A value low cost sound card
PostPosted: Tue Feb 08, 2005 1:47 pm
is there a good sound card for a low end(less than $50)?
PostPosted: Tue Feb 08, 2005 6:03 pm
If I had a budget of $50 I would buy this one.
PostPosted: Tue Feb 08, 2005 6:15 pm
Sound Blaster Live 5.1.
PostPosted: Tue Feb 08, 2005 6:25 pm
Yes, the Sound Blaster Live 5.1 is a good choice being much cheaper, depending on how you are going to use it and what kind of speakers you have you might want to save $25 and go with that.
What are you going to use it for and what kind of speakers do you have?
 Post subject: Re: A value low cost sound card
PostPosted: Tue Feb 08, 2005 10:47 pm
There was... I don't know if it's still available...
Hercules Fortissimo III
PostPosted: Wed Feb 09, 2005 2:43 pm
King of All Voodoo2 Cards
The SB Live cards are ass. When I get some spare change to swap the Live card out of one of my older machines I'm putting in some flavor of Audigy instead, if Creative didn't manage to fuck them up too.
You can get a Turtle Beach Riviera for $29.99 direct from Turtle Beach off their website, or you can get it for $17.99 direct from Turtle Beach through eBay.
Website :
http://www.turtle-beach.com/site/produc ... s/riviera/
eBay:
http://stores.ebay.com/Turtle-Beach_W0Q ... eZl2QQtZkm
PostPosted: Thu Mar 03, 2005 8:52 pm
good... great info,
i think the Hercules Fortissimo III would be a great pick since i saw tons of positive review.
Thx guys, continue to post good cards $50 or less
PostPosted: Fri Mar 04, 2005 6:55 am
http://www.sudhian.com/showdocs.cfm?aid=654 Another one to look at.
PostPosted: Fri Mar 04, 2005 8:18 am
Full fledge 7.1 catalina is $36 after rebate at newegg.com
PostPosted: Fri Mar 04, 2005 10:10 am
I'd still take the Santa Cruz over the both of them:
http://www.turtle-beach.com/site/produc ... risons.asp
PostPosted: Fri Mar 04, 2005 10:22 am
I have an Audigy LS that i found for 45.99 on newegg.com. I am very happy with it.
BTW: I had a Turtle beach Santa Cruz once and always had issues with it.
