It is currently Sat Feb 28, 2015 9:08 pm
 Post subject: PC3200 vs. PC4000
PostPosted: Tue Mar 01, 2005 10:44 am
Hey guys,
I'm putting together a system and was wondering what is better for overclocking, LOW LATENCY PC3200 or VALUE PC4000?
From current reviews, looks like I'll be getting the MSI Neo4 SLI board w/ an A64 3200+.
This will be my first attempt at overclocking, I've read many guides including the following:
http://tinyurl.com/48xlz
This guide states that if I get higher speed RAM, I can simply raise the FSB until it matches. This way I avoid dealing with memory timings and also means I save a few bucks on RAM:
Example:
http://tinyurl.com/6l3vm $82 vs. http://tinyurl.com/4rfg3 $115
Any advice will be appreciated.
TIA
PostPosted: Tue Mar 01, 2005 10:48 am
I don't know the answer to your question but you are more likley to find your answer if you post in Overclockers Corner
PostPosted: Tue Mar 01, 2005 10:55 am
why not just get this it has the same price as the 3200 low latency ram
PostPosted: Tue Mar 01, 2005 11:12 am
My goal is to save some money on the RAM. Two sticks @ $82 vs. $115 is about $66, which can go towards some other component.
I'm just wondering if I'll get the same OC results from using this cheap PC4000 ram than I would from using expensive PC3200.
PostPosted: Tue Mar 01, 2005 11:55 am
im not really sure, you should post in the overclocking part of the forum. Im leaning toward the pc3200 because i dont think you should ever buy cheap memory.
PostPosted: Tue Mar 01, 2005 12:07 pm
Ok. I'll try over there. I appreciate the help. Thx
PostPosted: Tue Mar 01, 2005 7:15 pm
just what you're looking for
