It is currently Mon Jan 26, 2015 12:03 pm
 Post subject: Best OCers Ram @ Best price
PostPosted: Fri Feb 11, 2005 5:43 am
1GB Kit HyperX DDR 400MHz 2-3-2-6
I know I know just give me love.
PostPosted: Fri Feb 11, 2005 12:35 pm
thats a good price for good baseline ram, for ocing tho that wont hold a candle to samsung tccd based ram
(waits for one4u2c to educate us on the matter)
as for ultra ocing this is prob the best value for pc4400
http://www.newegg.com/app/ViewProductDesc.asp?description=20-231-004&depa=1
237 dolars shipped, thats like less than half of the 2-2-2-5 DDR400 sticks of ram plus it is rated to oc like a mother and it will go down to 2-2-2-5 at stock
PostPosted: Fri Feb 11, 2005 1:12 pm
Contributing Writer
Contributing Writer
I don't know how the above would overclock, but a Google search would be likely to answer that. Awesome price for those timings, btw!
Someone mentioned recently that Kingston had their RAM on sale, so it's worth browsing their selection for anyone interested.
PostPosted: Fri Feb 11, 2005 1:58 pm
MaxPC tested the 5 fastest rated ram & this particular one was able to be OCed to 533 before it pooped out. If MaxPC says its the best I believe them. definitely (note that it is spelled correctly) not a baseline ram & I am running 2 pc2700 sticks now clocked up to pc3200 speeds.
PostPosted: Fri Feb 11, 2005 3:39 pm
Celeron
Celeron
Ahh... but the RAM that was tested in MPC's stress test was of a different type. This RAM you've listed I would expect would reach PC3700 speeds with 3-4-4-8 timings.
PostPosted: Fri Feb 11, 2005 3:54 pm
Yea your right my bad try this link everyone still a good value.
TCCD Hyper-X Best Price
