It is currently Mon Mar 02, 2015 7:50 am
 Post subject: Latency question
PostPosted: Mon Feb 07, 2005 9:22 pm
Would I see a big OC hinderance if I get memory with 2-3-2 instead of 2-2-2?
I figure not seeing as how they will lossened anyways but was just curious.
PostPosted: Mon Feb 07, 2005 9:28 pm
Contributing Writer
Contributing Writer
It depends, really. With whatever make/model RAM you have in mind, do a google search for reviews.
PostPosted: Tue Feb 08, 2005 10:10 am
I was looking at either Mushkin Hi Perf LII V2 2-2-2 or PDP with 2-3-2.
Ive read many reviews and I still dont have a clear answer about whats the best overclocking memory.
They say two brands with indentical specs but yet one of them will beat the pants off the other?
Or how retailers price their memory in very weird ways.
They price RAM with slower latenceys higher than they do faster ones.
Also can you explain to me what the difference is between these two is and why the price is different?
Corsair 1
Corsair 2
or why this one is more expensive then the other two
Cosair 3
Is it because they are matched?
Arent the other sets matched too?
Sorry I only used Corsair, if that ruffles any feathers, but it was the only company I could use to clarify my question.
PostPosted: Tue Feb 08, 2005 4:02 pm
Celeron
Celeron
The LII Mushkins will be the winner if we had a match up. But I've only seen people end up with results at just up to 250MHz, not matching OCZ's usual 260. In this case, the difference is that Mushkin uses Samsung TCCD chips, and PDP uses slightly slower Liberty chips. TCCDs also take a lower voltage to hit high frequencies.
Lately, I've discovered that the difference in memory performance for sticks using Samsung TCCDs is the PCB design. Currently, the best is the Brain Power PCB which OCZ, PDP, G. Skill and maybe a few others use. (Here comes the research leeching! :P:P:P;))
Corsair 1
Corsair 2
Cosair 3
First two, they're the same, and it's priced according to the retailer. The third one, I can't explain. It's probably up to the retailer again.
Hehe... sorry if I took this one from yah One4! :P
PostPosted: Tue Feb 08, 2005 6:48 pm
Yea I was looking at OCZ stuff too, but with the same timings as the PDP.
Is that the stuff I should plan on buying?
Thanks for the help though Noob.
PostPosted: Tue Feb 08, 2005 7:57 pm
Celeron
Celeron
The Samsung TCCDs rated at 2-2-2-5 @ PC3200 are the best. It's what basically every OC enthusiast wants to get. Only other option is the kick-ass Crucial Ballistix, which uses 2-2-2-6 timings @ PC3200 , and can also ramp up to at least 250MHz. They're based off of Micron Technology chips, which is what Crucial uses for their whole line.
If you haven't already, I suggest you read a couple of these articles by Anandtech. It shows what these things are capable of. Pick and choose:
Article Uno
Article Two
Article C
Article Cuatro
Article Five
Users browsing this forum: btdog and 12 guests
