It is currently Sat Feb 28, 2015 10:20 am
 Post subject: 2500@3200
PostPosted: Wed Feb 02, 2005 5:05 pm
How do I oc my XP 2500+? I heard that all you have to do is adjust the FSB to 400MHz, is this true?
PostPosted: Wed Feb 02, 2005 5:25 pm
Contributing Writer
Contributing Writer
If the multiplier is locked, yes. In the BIOS, you would adjust your CPU frequency to 200, which is a 400fsb double pumped.
PostPosted: Wed Feb 02, 2005 8:28 pm
Team Member Top 100
Team Member Top 100
Are the XP multipliers locked now? I guess I was lucky and got an unlocked 2700+. 8)
PostPosted: Wed Feb 02, 2005 10:02 pm
Contributing Writer
Contributing Writer
They've been locked for a long time now, but there's still some unlocked Bartons floating around. I have an unlocked Barton 2500+ in my kid's computer.
PostPosted: Wed Feb 02, 2005 10:08 pm
i have an unlocked 2500+ sitting in the comp next to my right arm :) of course theres an unlocked mobile 2500+ in my main comp
PostPosted: Thu Feb 03, 2005 10:02 am
Ok rather then starting a new thread i'll just ask a few questions about overclocking my 2500 in this thread. Basically I just messed with overclocking my 2500 yesturday and so far it looks like i can get the multiplier up to 12.5 and the FSB up to 170 and she'll run stable but then i tried stepping the FSB up a little higer to 172mhz and she stalled on me.. I noticed the temps were still straight and around 40c. So i figured she was getting a little power hungry so i bumped the vcore up to 1.70. I got her up to boot to windows with the fsb at 172mhz and multiplier at 12.5 but as soon as i started running benchmarks she would crash on mmx/sse testing. Not sure wether i should bump the vcore up anymore or if i should keep the fsb down and take it as the max she'll go..
my configuration is.
ASUS A7n8x rev 2.0
barton 2500
Corsair XMS platinum series dual channel 3200 1gb
Coolermaster aero 7+
Western d special edition 8mb 80gb
ATI AIW 9600xt
2 80mm coolermaster fans
cooldrive 4
Old school gateway battle case..
PostPosted: Thu Feb 03, 2005 11:26 am
the easyist OC with a 2500+ is just to leave the multi alone and just set the FSB to 200
PostPosted: Thu Feb 03, 2005 11:35 am
agreed but when i do this she cant seem to handle the FSB settings should i be bringing the vcore up and if so how high should i go before i should start to worry..
PostPosted: Thu Feb 03, 2005 3:41 pm
Celeron
Celeron
You want to scale that FSB as high as it can go. That means lowering your processor so that your memory is capable of a higher bandwidth, which equals more performance. Try again with the stock multipliers (11x).
For the VCore, at 1.75v you should proceed with extreme caution. And with that, make sure your cooling is ready.
PostPosted: Thu Feb 03, 2005 3:45 pm
I will try again tonite but basically i shouldn't go above 1.75 on the voltage correct....
PostPosted: Thu Feb 03, 2005 3:47 pm
Celeron
Celeron
Try it with stock voltages first, bump it if necessary. 1.85v is the voltage that no one should/need to exceed, unless going for a huge OC. 1.75v is within the safe zone of Athy XPs.
PostPosted: Thu Feb 03, 2005 4:22 pm
Team Member Top 100
Team Member Top 100
I always thought they were all unlocked, because every Athlon I've had (2 thoroughbreds, one barton) has been unlocked.
1x Thoroughbred 2400+
1x Barton 2500+
1x Thoroughbred 2700+
PostPosted: Thu Feb 03, 2005 4:46 pm
Contributing Writer
Contributing Writer
1x Barton 2500+
Nope. Everybody was taking their 2500+'s to 3200+ speeds, and they began locking them. IIRC, you need a pre-week 39 Barton.
PostPosted: Thu Feb 03, 2005 4:49 pm
1x Barton 2500+
man i got lucky and built mine about a year ago..
