It is currently Mon Apr 20, 2015 9:31 pm
 Post subject: SATA Cable Colors Question
PostPosted: Sun Oct 03, 2010 9:14 am
I built my rig using orange SATA cables. Noticed at Best Buy blue SATA II cables. Is there really a cable size difference between the colors for SATA I and II? Where on my system can I check if I am running SATA I or II?
 Post subject: Re: SATA Cable Colors Question
PostPosted: Sun Oct 03, 2010 1:17 pm
It doesn't matter it's just a color decided on by whoever made the cables.
PostPosted: Sun Oct 03, 2010 1:51 pm
Team Member [Top 500]*
If the motherboard controller supports SATA 2 and your drives are SATA 2 then you are running SATA 2. If the motherboard supports only SATA 1 and the drives are SATA 1 or SATA 2 then you are running SATA 1.
Cables as stated are just a matter of preference as there are no SATA 1 or SATA 2 cables.
Ron
PostPosted: Sun Oct 03, 2010 7:59 pm
On second thought I will sell you uber quality High speed gold plated SATA cables for $50 an inch that is $20 cheaper than best buy and they are limited edition black coloring :D
PostPosted: Sun Oct 03, 2010 8:23 pm
Million Club 5+ [PC]*
yeah SATA cables can be any color and there is no difference. in my experience most SATA cables are red but I have also seen black, yellow, and blue
PostPosted: Sun Oct 03, 2010 9:57 pm
I looked up my mobo and it's running SATA II so I was just worried when I saw cables with the SATA II label on them. Obviously worried my cables were bottlenecking my system. Thanks.
