It is currently Thu Jan 29, 2015 1:45 am
 Post subject: stock AMD cooler
PostPosted: Sun Jan 30, 2005 7:19 pm
I'm going to be picking up an AMD XP 3000+ and I want to OC the thing. I was wondering... is it worth buying an aftermarket heatsink for it or is the stock one that AMD gives you pretty decent? Also, if you recommend buying a new heatsink, which one would you suggest?
PostPosted: Sun Jan 30, 2005 9:36 pm
Contributing Writer
Contributing Writer
An XP 3000+ isn't going to have a lot of headroom in it, and an aftermarket hsf isn't likely to help. I'd recommend sticking with the stock until/if thermals prove to be the roadblock.
PostPosted: Mon Jan 31, 2005 8:36 am
Thanks for the advice One4.
PostPosted: Mon Jan 31, 2005 12:24 pm
Why would a 3000+ not have much headroom?
PostPosted: Mon Jan 31, 2005 2:11 pm
Contributing Writer
Contributing Writer
Because it's nearing the end of what that Barton core is capable of. The XP's stopped at 3200+, and those are really poor overclockers. Not much can be expected expected out of a 3000+ XP.
Don't confuse the 3200+ XP with the A64 3200+. :wink:
PostPosted: Mon Jan 31, 2005 3:30 pm
OH, thats what I did.
I dearly stand corrected.
Thank you my good man.
