It is currently Thu Apr 02, 2015 2:03 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 07, 2005 12:34 pm
whats the highest(and still stable) i can get my bus up to with stock cooling
PostPosted: Tue Feb 08, 2005 3:33 pm
Celeron
Celeron
We can't tell you, but you should be capable of 2.6 (where your CPU will run out before your RAM would.)
PostPosted: Tue Feb 08, 2005 5:22 pm
are you sure, on stock cooling :?:
PostPosted: Thu Feb 10, 2005 7:09 pm
Mobo: MSI NEO2-F (K8T800 pro)
Core(newcastle or winchester): newcastle
Speed: 2.62
Bus: 239
Multiplier: 11x
Voltage: +3.3%
Cooling: stock
Ram(speed ie:DDR400@stock): DDR400@stock
Latency(memory timings): 3
Idle temps(C): 38-44C
Load temps(C): 55-74C
damn this XaserV got crazy airflow
PostPosted: Mon Feb 14, 2005 10:31 am
One4yu2c wrote:
Kybo_Ren wrote:
Changing them did nothing for me last night :-\
It's going to do 'something,' you're just not likely to notice it. Test your memory bandwidth at 2-2-2-5 and 2-2-2-10, then compare the results.
SiSoft Sandra
I ran it with both setting and the results were the same, oh well I left it at 10 anyways
PostPosted: Wed Mar 02, 2005 9:12 pm
Mobo: MSI-K8N Neo2
Core: Newcastle
Speed: 2.6GHz
Bus: 260MHz
Multiplier: 10
Voltage: 1.58V
Cooling: Air- Thermalright XP-90
Ram: OCZ PC4200
RAM timings: 2.5-3-3-8
Idle temps(C): 37
Load temps(C): 49
Users browsing this forum: mrmarrero and 7 guests
