It is currently Sat Jan 31, 2015 10:00 pm
 Post subject: Ram OC question
PostPosted: Fri Jan 21, 2005 8:11 am
Im wondering if this is a decent OC?
I have 1GB of Corsair TWIN3200 XL PRO and I got the FSB up to 219 and was able to maintain timings of 2-2-2-5 1T.
also wondering if this is on par with what everyone else is getting and if you think I could run it higher. Maybe with some diffent timings?
A64 3500+ Newcastle
Asus A8V Deluxe
PostPosted: Fri Jan 21, 2005 1:06 pm
Celeron
Celeron
That is damn good.
If you want to take it a bit further, switch the "5" to a "10" and try again. You should be left with 2-2-2-10 timings. If that doesn't work, loosen the timings up a notch, like 2.5-3-2-7 (I'm pretty sure the "10" trick doesn't work for VIA chips.)
